Kutt
- 237
- 1
If the universe is finite in size, what is at the very edge of it?
The discussion centers on the concept of a finite universe and its potential boundaries. Participants clarify that a finite universe does not necessarily imply an edge, drawing parallels with Earth, which is finite yet lacks a definitive edge. The conversation explores multidimensional projections, suggesting that while our universe may be finite, it could exist in a higher-dimensional space without a physical edge. Key analogies include the behavior of two-dimensional creatures on a sphere, illustrating the complexities of perceiving higher dimensions.
PREREQUISITESCosmologists, physicists, mathematicians, and anyone interested in the philosophical and scientific implications of the universe's structure and dimensions.
Kutt said:If the universe is finite in size, what is at the very edge of it?
micromass said:Finite in size \neq has an edge.
Look at our earth: it's finite in size but it doesn't have an edge.
Kholdstare said:I think OP is referring to the 3D projection of the multidimensional universe (or as we normally see it). Although multidimensional universe might not have an edge, our 3D representative one might have one.
e.g. circle, which is a projection of a sphere in 2D.
micromass said:Projection of the universe on what?? The universe is all that there is![]()
Kholdstare said:When an apple is cut in two halves, the apple is all that there is. Yet we get a projection of apple in 2D by the framework defined by the movement of a knife. That framework has no existence, yet the apple is cut.
nitsuj said:Seriously though, I am on the edge of the Earth.
micromass said:Universe \neq apple.
Making physical statements based on loose analogies like this is very dangerous.
jgens said:I think micromass is looking at the Earth as a sphere rather than a ball.
Kholdstare said:Would you explain how it is a loose analogy?
I think nitsuj meant boundary, when he said "edge". It determines whether you are inside or outside.
Imagine a two dimensional creature living on a plane. If the plane is finite, then it has a boundary line around it and the creature can't go beyond that boundary because that's the edge of the universe. Now consider a creature living on the surface of a very large sphere. To the creature, it seems that the universe is a plane if the radius is large enough. Such a creature lives in a finite universe, but it has no edge. Now think about how we may be living in a finite 4 dimensional curved universe that has no edge.nitsuj said:Sorry I'm not sure of the difference
Jimmy Snyder said:Imagine a two dimensional creature living on a plane. If the plane is finite, then it has a boundary line around it and the creature can't go beyond that boundary because that's the edge of the universe. Now consider a creature living on the surface of a very large sphere. To the creature, it seems that the universe is a plane if the radius is large enough. Such a creature lives in a finite universe, but it has no edge. Now think about how we may be living in a finite 4 dimensional curved universe that has no edge.
Do you mean to tell me that you can't imagine a 3 dimensional object curved in the 4th dimension? Yeesh.nitsuj said:I totally appreciate that popular analogy, I find the transition from 2D to 3D is lost on me though![]()
Containment said:Cheese lots and lots of it.
Jimmy Snyder said:Do you mean to tell me that you can't imagine a 3 dimensional object curved in the 4th dimension? Yeesh.
I was not suggesting that there are more than 3 spatial dimensions. Although I didn't specify what the 4th dimension was, I was thinking of time. More correctly, I was thinking of 4 dimensional space-time.Kholdstare said:We might be living in that or something else. If we can never literally experience the higher dimensions (except time) in any way, we will never be sure that there exists more than three. One may argue the possibility, but it remains as mathematical one as no convincing evidence can be gathered.
This is not correct. The angles on a triangle on a sphere add up to more than 180 degrees. A 2D creature could measure it and so detect the third dimension. In similar fashion, if we measure the angles of a triangle to be more or less than 180 degrees, we too would have concrete evidence of curvature.Kholdstare said:Think of an an ideal 2D creature on that sphere (a dot, not an ant, not even a human). Whatever the dot does it will never find the edge of the sphere. However, he might suspect the sphere to be 3D if he is an intelligent creature (his ability only comes from some example in his own 2D world). But having never experienced the 3rd dimension in any way he'll never realize/believe/have evidence of this being true. (Remember he is incapable of imagining anything 3D (cause he's never been a 3D creature himself)).
Jimmy Snyder said:I was not suggesting that there are more than 3 spatial dimensions. Although I didn't specify what the 4th dimension was, I was thinking of time. More correctly, I was thinking of 4 dimensional space-time.This is not correct. The angles on a triangle on a sphere add up to more than 180 degrees. A 2D creature could measure it and so detect the third dimension. In similar fashion, if we measure the angles of a triangle to be more or less than 180 degrees, we too would have concrete evidence of curvature.
The bending of light near the surface of the sun is an example of just such a measurement. This is evidence that space-time is indeed curved, but does not answer the question of whether the universe is so curved that it closes in on itself like a sphere.
Kholdstare said:But having never experienced the 3rd dimension in any way he'll never realize/believe/have evidence of this being true.
I'm confused.Kholdstare said:I'm not telling that he'll not find evidence of the 3rd dimension.
Jimmy Snyder said:I'm confused.
Unanswerable question.Kutt said:If the universe is finite in size, what is at the very edge of it?
Bounded yet infinite is a mathematical concept. Physical objects which have boundaries are, either observationally or by definition, not infinite.Kholdstare said:Its boundary, which lies at infinity.![]()
What would you call the outer crust? What about an expanding wave shell ... in any medium?micromass said:Finite in size \neq has an edge.
I think the OP is asking a very straightforward, and unanswerable, question about the possible nature of our universe. Eg. our universe might be a bounded finite entitiy (eg., the interior of a 3D wave shell in some medium of unknown strutcture). If, per the OP, the universe is "finite in size", then, by definition, the universe under consideration isn't infinite, and has a boundary, or edge. (The boundary or edge being, presumably, the same 'stuff' that mediates the interior. Which remains unknown.)Kholdstare said:I think OP is referring to the 3D projection of the multidimensional universe (or as we normally see it). Although multidimensional universe might not have an edge, our 3D representative one might have one.
"All that there is" can refer to some metaphysical speculation or it can refer to all that's amenable to detection. Either case can be projected onto a speculative preexisting background.micromass said:Projection of the universe on what?? The universe is all that there is![]()
My favorite reply.SW VandeCarr said:A cop. If you ever got there, you definitely must have been speeding.
BTW, despite what everyone here has said, I'm convinced it's somewhere in the state of Nevada.
No there is a precise mathematical distinction micromass is making. Space - time is a 4 - manifold that is not embedding in some ambient space.nanosiborg said:"All that there is" can refer to some metaphysical speculation or it can refer to all that's amenable to detection. Either case can be projected onto a speculative preexisting background.
Amazing that you can tell that from what he wrote:WannabeNewton said:No there is a precise mathematical distinction micromass is making. Space - time is a 4 - manifold that is not embedding in some ambient space.
It's more amazing than that. I was able to tell the same thing.nanosiborg said:Amazing that you can tell that from what he wrote:
