I'm building a house (and infrastructure) in Ecuador
  • Thread starter Thread starter sbloomquist
    Building
The discussion centers on constructing a house and infrastructure in coastal Ecuador, specifically addressing the weight-bearing capacity of a 20m steel tube, 1/4" thick and 8" in diameter, intended for a bridge to support a 20-ton tanquero. The original poster is advised to consult a local expert in building planning and construction due to the complexities of building on a 30% slope and the necessity of obtaining appropriate permits and inspections. The importance of local expertise and compliance with regulations is emphasized as critical for successful construction.
  • Understanding of structural engineering principles
  • Knowledge of local building codes and regulations
  • Familiarity with construction materials, specifically steel
  • Experience with construction permits and inspections
  • Research the weight-bearing capacity of steel tubes using engineering formulas
  • Learn about local building codes and regulations in Ecuador
  • Investigate the properties of different steel grades, particularly those sourced from China
  • Explore best practices for building on sloped terrain
Home builders, civil engineers, construction project managers, and anyone involved in infrastructure development in challenging terrains.
sbloomquist
I am going to construct a house in coastal Ecuador and will be asking questions related to building infrastructure to support it. It will be a built on a 30% slope and I am seeking information related to construction materials.
My first question: what is the weight bearing capacity of a 20m steel tube, 1/4" thick and 8" in diameter? I need to build a bridge that will support a 20t tanquero. I have steel tubes available to me, but I do not know the origin of the steel (probably Chinese, if that helps).
Temporarily closed for moderation.
Welcome to the PF.
We do not help with projects like this. You need to find a local expert in building planning and construction to help you, rather than trying to mine the Internet for help. You should also try to do this construction using the appropriate permits and inspections, especially trying to build on a slope. I have several friends who had the skills to build their own homes, and they all did it using permits and had the final product inspected.
Thread will stay closed.
  • · Replies 28 ·
9K
  • · Replies 59 ·
