Is [A-] greater than [H3O+] in a 1M solution of highly acidic HA?
The discussion centers on the relationship between the concentrations of the conjugate base [A-] and hydronium ions [H3O+] in a 1M solution of a highly acidic weak acid (HA). It is established that the dissociation of HA in water produces equal concentrations of H+ and A-, leading to the conclusion that [H3O+] = [A-] under complete dissociation conditions. The confusion surrounding the role of hydronium ions is clarified, noting that H+ ions associate with water to form H3O+, which is a common representation in acid-base chemistry.
  • Understanding of acid-base chemistry, specifically the Arrhenius definition of acids.
  • Knowledge of pH and its calculation as the negative logarithm of hydrogen ion concentration.
  • Familiarity with chemical stoichiometry and reaction equations.
  • Basic concepts of dissociation in aqueous solutions.
  • Study the Arrhenius, Brønsted-Lowry, and Lewis definitions of acids and bases.
  • Learn about the dissociation constants (Ka) for weak acids and their implications on equilibrium.
  • Explore the concept of hydronium ions and their role in acid-base reactions.
  • Investigate the effects of concentration and volume changes on pH in solutions.
Chemistry students, educators, and professionals involved in acid-base chemistry, particularly those focusing on the behavior of weak acids in solution.
HazyMan
The question says: A solution of highly acidic HA is given, with a molarity of 1M. Is it true that [A-]>[H3O+] or not? I simply don't understand why the hydronium is mentioned and i don't know how to find the molarity of these two individually.
Chemistry news on Phys.org
What is an acid?
What does it mean "highly acidic" in the context of water solution?
Borek said:
What is an acid?
acid= substance with pH<7
solution of highly acidic HA= a highly acidic substance is solute in water?
No, pH is not a property of an acid. It is property of a solution. Oxalic acid is a solid and as such it has no pH, yet it is still an acid.
How is pH defined?
Why is it lower than 7 when there is an acid present?
How is pH defined?
Sorry for being late, i believe pH is derived as the negative logarithm of the acid's molarity (moles of H+ divided by the solution's volume)
I suppose that the acid is being dissolved in the water, releasing H+ ions. This might be wrong (aswell as the H+/V derivation i mentioned in the previous parenthesis perhaps) because i don't know if these ions will react with the water in the solution.
Yes. Just that's not something to "suppose", that's a definition of an acid (more precisely: Arrhenius definition, there are other, more general definitions).
Ignoring water (the solvent) for a moment, what can you tell about concentrations of H+ and A-? (think in terms of stochiometry, try to write reaction equation of HA dissociation).
I think the equation is HA->H+ & A- .
Obviously 1 mol of HA gives 1 mol of H+ and 1 mol of A- so the mole number of H+ and A- are equal. Since there is no change in volume, the concetrations of H+ and A- should also be equal. Therefore [H3O+]=[A-].
What confused me about the original question was the hydronium, but i later found out that it's the same thing as H+, something that i still can't understand quite so well but I've accepted it.
Only if the dissociation went to completion. That's not always the case.
That would actually hold always, when there are no other sources of H+.
That's approximately correct, but you have also dissociating water.
To some extent H+ and H3O+ are equivalents. See https://en.wikipedia.org/wiki/Hydronium
What exactly does that mean?
There is more than one source of hydronium in the solution. Told you that in the other thread.
Is that other source the water solvent?
Yes.
  • · Replies 19 ·
9K
