I'm getting garbage values while reading matrices from a file
12 replies · 3K views · last reply
kranthi4689
Hi All,
While trying to read a matrix from data file using fortran90 code ,I get garbage values and a backtrace error.
Error termination. Backtrace: #0 0x7f4a4de3631a #1 0x7f4a4de36ec5 #2 0x7f4a4de3768d #3 0x7f4a4dfa4d42 #4 0x7f4a4dfa6ad5 #5 0x7f4a4dfa80f9 #6 0x56040bbeae57 #7 0x56040bbeaf93 #8 0x7f4a4da4bb96 #9 0x56040bbeaa29 #10 0xffffffffffffffff
The code I use is
[CODE title="read_file.f90"]program read_file
implicit none
integer :: ios,i,j
character (len =40) :: str_name
character (len=1000) :: line
integer , dimension (10) :: vect
real , dimension (11,16) :: hamilt
str_name = ' OVERLAP MATRIX - CELL N. 1( 0 0 0)'
open(unit=20,FILE='data.txt',iostat=ios,status='old')
if ( ios /= 0 ) stop "Error opening inputfile"
do
read(20,'(A)',end=100) line
if (line(1:40) == str_name ) then
write (*,*) "found line"
write (*,*) line
!read (20,*) (a(i,j), j = 1,16))
do i = 0,10
read (20,*,end =100) (hamilt(i,j), j=1,16)
write (*,*) hamilt(i,j)
enddo
endif
enddo
100 close(20)
end program
[/CODE]
I attached my data file. I want to read the matrix that starts after str_name.
Kindly help me in understanding the error in my code. thank you.
Are you reading this files into some other software, say, Excel, or is this self-contained?
@WWGD I just want to read them and write them in a separate txt file.
kranthi4689 said:
Fortran:
          do i = 0,10
          enddo
1st error: i starts at zero, but Fortran array indices start at 1.
2nd error: the structure in the file doesn't follow what you are doing here. The outer loop should go from i = 1 to 16, then the inner loop should go from 1 to min(i,10). You then have to add code to read the rest of the matrix (since only the first 10 columns are found in the first block).
Forgot the third error: you are neglecting to read the index that appears to the left of the matrix elements.
I rectified the code to address the errors, but I still get segmentation faults.
Code:
 read (20,*) (vecy(i), j = 1,10) ! read column index
          do i = 1,16
             do j = 1,min(i,10)
                 read(20,*,end=100) vecx(i) , hamilt(i,j) ! row index and matrix elements
               enddo
          enddo
         endif
You can't read vecx inside the j loop. You have to use an implicit loop as before.
reading it out the loop is giving a fortran runtime error.
Fortran:
read (20,*,end =100) vecx(i), (hamilt(i,j), j=1,min(i,10))
DrClaude said:
Fortran:
It worked Thank you. Could you kindly recommend a book or site or some material from where I can learn fortran efficiently. Thank you.
Wow, I thought Fortran was a dead language outside of dealing with legacy systems.
A few good links:
https://www.fortrantutorial.comhttp://www.usm.uni-muenchen.de/people/puls/lessons/intro_general/f90_for_beginners.pdfhttp://pages.mtu.edu/~shene/COURSES/cs201/NOTES/fortran.html
But if I may, I would like to point out that the problem you were having has nothing to do with Fortran per se. I have a feeling you would have stumbled whichever language was used. It is important to decompose what needs to be done step by step and then program these steps.
Far from it. Especially with the newer versions of Fortran, the language has now most of the features of modern languages. I would say that for numerical computations, it is still one of the best options available.
No, not dead at all, my lab uses it exclusively for large scale computational efforts. I'd convert to C++ but I'm the youngest member of my group and the other 4 members don't know a line of C/C++, so we are continuing with Fortran for the time being, when they start to retire, we'll convert over.
