Image processing with Sobel Edge detection
9 replies · 3K views · last reply
btb4198
I am coding Sobel Edges detection in C#.
I have a method that converts my image to grayscale.
it adds the R G and B values and divides by 3. and replaces the R G and B value out with that same number. That seems to be working fine.
Two side-by-side grayscale portrait photos of a man with short brown hair facing the camera against a light grey backdrop, with a grey Enter button below.
Then I added a gaussian blur to it by using this :
_kernel = new int [9]{1,2,1,2,4,2,1,2,1};
and doing a convolution to my Image that is in grayscale:
Two side-by-side grayscale portrait photos of a man facing forward against a plain light background; the right one is a faded, overlapping ghost-like composite of the same face.
I guess that is working ...
At this point I do two more convolutions. One for the x-axis and one for the y axis. I perform both separately on the same image that now has a grayscale and gaussian blur applied to it.
I do a convolution for X using this :
_kernel = new int[9] { -1, 0, 1, -2, 0, 2, -1, 0, 1 };
with my Image and store that result in a new array called resultX[,]
and then I do another convolution for Y
using this:
_kernel = new int[9] { -1, -2, -1, 0, 0, 0, 1, 2, 1 };
and store that result in another array resultY[,]
Mentor note: added code tags and fixed the problem of disappearing array index that caused subsequent text to be rendered in italics.
Then I do this:
C:
int i = 0;
for (int x = 0; x < Row; x++)
     for (int y = 0; y < Column; y++)
         byte value = (byte) Math.Sqrt(Math.Pow(resultX[x, y], 2) + Math.Pow(resultY[x, y], 2));
         result[ i] = value;
         result[ i + 1] = value;
         result[ i + 2] = value;
         result[ i + 3] = 0;
         Angle[x, y] = Math.Atan(resultY[x, y] / resultX[x, y]);
         i += BitDepth;
return result;
but My image is black :
Left: grayscale photo of a man's face, front view against a plain light background. Right: nearly all-black image with only faint outlines of the face.
any Idea of what I am doing wrong?
I checked my convolution method and it is work just like how this guy says it should:
[/i]
I'm not completely sure without seeing the graphics statements, but"
I don't see what the result[] variable is, or what you are doing with it.
Shouldn't you store the absolute gradients in a two-dimensional array?
The Angle[x,y] will contain values from -π/2 to +π/2. You'll want to add, another π if the x-gradient is negative. If you use this directly for an image, the values with a max of 1.57 will all look black.
If you want something like in the video, you'll need to use the magnitudes of the gradients as the brightness, and convert the angles into a color value.
Question 1)
Sorry it should be:
C:
        private byte[] RunEdgeDetectionForByteArray()
            byte[] result = new byte[Size];
            double[,] Angle = new double[Row, Column];
            SodelEdgeDetectionX();
            double[,] resultX = RunConvolution();
            SodelEdgeDetectionY();
            double[,] resultY = RunConvolution();
            int i = 0;
                    result[ i] = value;
                    result[i + 1] = value;
                    result[i + 2] = value;
                    result[i + 3] = 0;
                    i += BitDepth;
            return result;
question 2)
I have another function that convert result[] into a bitmapImage. that is why I do not keep it in a 2D array.
I am sorry but I do not understand the second part :
"The Angle[x,y] will contain values from -π/2 to +π/2. You'll want to add, another π if the x-gradient is negative. If you use this directly for an image, the values with a max of 1.57 will all look black.
If you want something like in the video, you'll need to use the magnitudes of the gradients as the brightness, and convert the angles into a color value."
what do you mean?
@btb4198, please use code tags around your code. I have added them in your two preceding posts. A problem you have encountered is with arrays with an index of i. An expression such as "result" renders everything after "result" in italics, which causes your code to lose some information.
I have repaired the problem in the preceding posts. There is a sticky at the beginning of this forum section that explains how to use the code tags.
Take a look at the code again. Because of an array index with i inside brackets, the code consumed the brackets and index, and converted everything following to italics.
what do you mean?
You have a grayscale image in result[]. Doesn't that display anything?
The gaussian blur will make the gradient values you get lower, so you might have to multiply that by a constant (and clip values at the maximum value of a byte)
And then you have an array of gradient angles as doubles with values between -1.57... and +1.57... in Angle[x,y]. I don't think that will display as an image in any library you might be using. In the video they convert this angle to the colour used for displaying what is in result[]
1) yes I sent a picture of the grayscale.
What do you meant in the video they covert this angle to the colour used for displaying? I don't remember he saying anything like that ?
What time of the video are you referring to?
In the video he talks about gray scale.
Also, I am not doing anything with the Array of angles. Because he never says what to do with them.
The only thing I can think of is that the values of the gradients are less then you expect. Anti-aliasing in the original image will often put pixels with intermediate values on edges, and the gaussian blur will decrease contrast more. The range of values of a byte is 0-255, if your result values are 0..20, it might all look black.
If that doesn't work, I think there's something wrong with the format of result, or the method you use to display it, but I can't tell it without knowing what graphics/image processing library you are using.
If you look at 6:00 in the video you can see where the angles are used to get a colour from the colour wheel to colour the edges.
Are you also quite sure that resultX and resultY are actually filled? I can't see the class declarations and the implementations of the other class methods, because none of them have explicit parameters.
Ok I compared my gaussian blur to adobe illustrator and mines is not working. I did everything the guy said in the video for do Convolution
here is my code:
Code:
     public BitmapSource ApplyGaussianBlur(BitmapImage bitmapImage)
            if (bitmapImage == null) return null;
            Image = RunGrayScale(bitmapImage);
            GaussianBlur25();
            double[,] resultBlur = RunConvolution();
            BitmapSource bitmapSource = MakeBitmapSourceAfterNewFilter(resultBlur);
            return bitmapSource;
   void GaussianBlur9()
            _kernel = null;
            _kernel = new double [9]{1,2,1,2,4,2,1,2,1};
            ConvolutionRangeX = 1;
            ConvolutionRangeY = 1;
            reciprocal = 0.0625D;
        void GaussianBlur25()
            _kernel = null;
            _kernel = new double[25] { 1, 4, 7, 4, 1, 4, 16, 26, 16, 4, 7, 26, 41, 26, 7, 4, 16, 26, 16, 4, 1, 4, 7, 4, 1 };
            ConvolutionRangeX = 2;
            ConvolutionRangeY = 2;
            reciprocal = 0.003663D;
 public double[,] RunConvolution()
            if (Image == null || _kernel == null) return null;
            double[,] result = new double[Row, Column];
            for (int x = 0; x < Row; x++ )
                    result[x, y] =  ConvolutionMath(y,x);
            return result;
        }        private double ConvolutionMath(int yLocation, int xLocation)
            double value = 0D;
            double valuetest = 0;
            int maxY = yLocation + ConvolutionRangeY;
            int minY = yLocation - ConvolutionRangeY;
            int maxX = xLocation + ConvolutionRangeX;
            int minX = xLocation - ConvolutionRangeX;
            int j = 0;
            for (int x = minX; x <= maxX; x++)
                for (int y = minY; y <= maxY; y++)
                    if (y >= 0 && y < Column && x >= 0 && x < Row)
                        valuetest = (_kernel[j] *Image[x, y]);
                        value = value + valuetest;
                    j++;
            value = value * reciprocal;
            return value;
I tested this by hand, I am doing the same thing the guy from the video is doing
