Implementing a PriorityQueue w/ a Doubly-Linked List (Java)
  • Context: Comp Sci
  • Thread starter Thread starter Enharmonics
    Java List
2 replies · 4K views
Enharmonics
Basically, as the thread title says, I've got to implement a Priority Queue with a Doubly-Linked List in Java.
This is an excerpt from the instructions for the assignment:
I've assumed that priority is given to larger integers (since it wasn't specified in the instructions), but will ask my professor for specifics next time I'm in class
I've actually got the code more-or-less working as intended. Here it is (some non-crucial methods omitted for brevity):
Java:
public class LinkedList
    // A private nested class that represents the actual "links",
    // or "nodes", in the LinkedList
    private static class Link
        // Data fields for the Link class. Visibility
        // doesn't matter since it's a private nested class
        // The actual data that will be stored in each link
        public int data;
        // A reference to the next link in the list
        public Link next;
        // A reference to the previous link in the list
        public Link previous;
        // Constructor for the Link class
        public Link(int d, Link n, Link p)
            data = d;
            next = n;
            previous = p;
        // Returns the data stored inside a link
        // as a String.
        public String toString()
            return data + "\n";
    // Data fields for the LinkedList class
    private int listSize;
    // This node will at first serve to mark
    // the beginning of the list, but will
    // then be updated to be the newest link
    // added to the list (that is, the "first
    // link" in the list)
    private Link firstLink;
    // This node marks the end of the list
    private Link lastLink;
    // Constructor for the LinkedList() class
    // Uses the reset method to initialize
    // the LinkedList
    public LinkedList()
        reset();
    // Methods of the LinkedList class. Note that these are all standard
    // for a LinkedList class (they can all be found in Oracle's documentation
    // for the "official" LinkedList class located in the java.util package)
    // Accessor for the lists' size
    public int getSize()
        return listSize;
    // Returns true if the list is empty
    public boolean isEmpty()
        return getSize() == 0;
    // New implementation of add method for the priority queue problem.
    // This will automatically add elements into the list
    // in priority order
    public void add(int element)
        // First we create a new Link, storing
        // the data passed into the method in it
        // and setting its "next" pointer to the previous
        // top link in the list
        Link newLink = new Link(element, firstLink, lastLink);
        // First, check if the list is empty. If it is, then
        // the new link is also the "highest priority" link (of course,
        // it would also be the "lowest priority" link in that case)
        if (isEmpty())
            lastLink = newLink;
            // The current first link is now the "next"
            // link after the new link we just created
            newLink.next = firstLink;
            // Our new "first link" is now the newly-created
            // newLink, since that is now the top link in the list
            firstLink = newLink;
        // Next,, we iterate through the list
        // looking for the first link whose priority
        // is lower than the element we are attempting to add
        else
            // Now we need 2 more links: one to store the link
            // with the highest priority (assumed at first to
            // be the "first link", and the other to point
            // to the link with the highest priority)
            Link current = firstLink;
            Link previous = current;
            Link temp;
            // Iterate through the list, looking for value
            // with highest priority
            while (element <= current.data && current != null)
                previous = current;
                current = current.next;
            // After the while loop completes, either we have found
            // a link whose element has lower priority than the one
            // we are trying to insert or we are at the start of the list
            // (that is, the position of lowest priority); either way,
            // we have found the proper place to insert our new element
            temp = current;
            previous.next = newLink;
            newLink.previous = previous;
            newLink.next = temp;
            // Get rid of temp
            temp.previous.next = newLink;
            temp.previous = newLink;
        // Increment the size of the list
        listSize++;
    // Removes and returns the first
    // element in the list
    public int remove()
        // This will store the data in the top
        // link so that we can return it later.
        int removedData = firstLink.data;
        // This
        // In order to remove the link, we simply set
        // firstLink to be the "next" link in the list
        // (that is, the previous firstLink)
        firstLink = firstLink.next;
        // Decrement the size of the list
        listSize--;
        // Return the data stored in the link we just removed
        return removedData;
    // Returns the Link with the highest
    // priority element in it
    public Link findMax()
        // Same logic as add() method. We will use these to iterate
        // through the list and to remove the link with the highest
        // priority value
        // This will store the current highest priority
        // value
        int currentHighest = firstLink.data;
        // This will store the value itself, which will be returned
        //int maxPrio;
        // Iterate through the list, looking for the highest priority
        // element
        for (int i = 0; i < listSize; i++)
            // If the current Link's element is less than or equal to
            // than the current highest priority value and
            // the current link isn't the last link in the list,
            // continue iterating
            if (current.data <= currentHighest && current != null)
            // Otherwise, the current Link element must
            // be greater than currentHighest, so update currentHighest
            // and continue the search
            else
                currentHighest = current.data;
        // Current is the highest priority element, so return it
        return current;
    // Removes and returns the highest priority
    public int removeMax()
        // Call the findMax() method to
        // find the link with highest
        // priority
        Link removeLink = findMax();
        // Store the data to be returned
        int maxPrio = removeLink.data;
        // Removes the link with highest priority value
        removeLink.next.previous = removeLink.previous;
        removeLink.previous.next = removeLink.next;
        // Decrement list size
        listSize--;
        // Return highest priority element
        return maxPrio;
    // Returns the highest priority
    public int max()
        return findMax().data;
        //return firstLink.data;
    // Empties the list using the reset method
    public void clear()
        reset();
    // This method creates the first link and sets the size of the list
    // to 0. It can be used during instantiation and to clear the list
    private void reset()
        // The method now creates the first AND last nodes, and
        // connects them to each other by setting lastLink's previous
        // pointer to firstLink. New links will be
        // inserted "between" them.
        //firstLink = new Link(0, null, null);
        firstLink = new Link(0, lastLink, null);
        lastLink =  new Link(0, null, firstLink);
        listSize = 0;
Particularly, my problem seems to be with the add() method.
I wrote a driver to test the class (as the instructions say to do). Short excerpt from it:
Java:
PriorityQueue myQueue = new PriorityQueue();
        // Let's test the add() method first
        System.out.println("\n--- TEST THE add() METHOD, PART 1---\n");
        myQueue.add(1);
        // There should be an item in the queue now
        System.out.println("Queue size: " + myQueue.getSize());
        // add() METHOD TEST 1 PASSED.
        // Let's test the max() method. Since 1 is the only
        // item in the queue, of course it should be the max
        System.out.println("\n--- TEST THE max() METHOD, PART 1 ---\n");
        System.out.println("Highest priority item: " + myQueue.max());
        // Let's try adding an item of higher priority now
        myQueue.add(3);
        System.out.println("\nQueue size: " + myQueue.getSize());
        // Let's test the max() method again. This time, the max should
        // be 3, since 3 is greater than 1 and thus has higher priority
        System.out.println("\n--- TEST THE max() METHOD, PART 2---\n");
The output for the above driver code is:
Queue size: 1
Highest priority item: 0
Queue size: 2
Highest priority item: 3
So far, so good. But then I tried adding another element:
Java:
// Another test for the max() method. First, we'll add 2 to the list.
        // 2 is smaller than 3, so it should have lower priority.
        myQueue.add(2);
        myQueue.display();
        System.out.println("\n--- TEST THE max() METHOD, PART 3 ---\n");
        // The max should still be 3
And here's the output (previous output omitted for brevity)
[previous output goes here]
Highest priority item: 1
Ouch. Given the fact that the 2 appears in the correct spot, but for some reason the 3 has been replaced by another 1, I assume there's some kind of problem with the logic in the add method. At the time of writing this post, I've been up for over 32 hours straight, because I ended up spinning my wheels through the whole night trying to figure out how to fix this. I just don't know what's wrong, and it seems like thinking about it only makes me more confused now.
My hunch is that it's got something to do with how I iterate through the list (using the previous and current pointers) and how I "insert" newLink into the list, but I don't understand why it would work properly the first two times and not the next.
Maybe I'm misreading; I haven't actually compiled the code and gone through it with a debugger. But here are some thoughts, for what they're worth.
When the List is initially constructed Two Links are instantiated in the method reset(). These two Links appear to me to be "dummy" links that are initially assigned to the List's "firstLink" and "lastLink" properties. This happens before the add() method is ever called.
Code:
        listSize = 0;
So even before the add() method is called, there are two instances of Link that exist.
When the add() method is first called, a third instance of Link is created, called newLink,
Link newLink = new Link(element, firstLink, lastLink);​
and then the following block of code is executed:
Code:
        if (isEmpty())
            lastLink = newLink;
Let's go through that line by line.
lastLink = newLink;​
There's still a reference to the old instance of newLink lastLink stored in the firstLink instance, so the garbage collector won't clean up the previous lastLink just yet.
newLink.next = firstLink;​
Now newLink's "next" reference is pointing to the dummy instance called firstLink.
firstLink = newLink;​
Now firstLink is a reference to the new instance of Link, newLink.
Something to keep in mind at this point. There are still 3 instances of Link. No garbage collection has been done since references to each instance still exist.
newLink.next points to the old dummy instance that was once called firstLink. Now this instance doesn't have that name, but a reference to it still exists.
The old lastLink still exists too since the old firstLink (now referenced through newLink.next) still refers to it.
I don't find the "next" and "previous" properties of the dummy Instances ever being updated at all.
I'm not sure if this is this is what you want to do. It seems hard to follow, and something about it doesn't seem quite right. I'm assuming that the problem may be in this part of the code somewhere. [Edit: Rather than reassign, lastLink = newLink, and firstLink = newLink, maybe you should rather change the "next" and "previous" properties of lastLink and firstLink. That might be what is going wrong here.]
Another related thing: If you do intend of keeping the dummy instances around, rather than give them both priority 0, give one of them priority 0 or maybe a negative priority (like int.MIN_VALUE), and the other one one the maximum possible priority (like int.MAX_VALUE). Then when searching for Link elements, make a check so you don't accidentally return either of those. -- Or for a different paradigm, make your List so that it doesn't need these dummy Links.
Code:
        listSize = 0;
Code:
        if (isEmpty())
            lastLink = newLink;
You're absolutely right. Thanks so much for pointing that out. I hadn't realized that I had been overwriting firstLink and lastLink repeatedly rather than actually inserting "between" them by using their next and previous pointers. As soon as I sorted that out, things got better. That's what I get for trying to pull an all-nighter with no breaks, I guess. Thanks again for the help!
