Implicit Differentiation with Trig
The discussion focuses on finding the slope of the tangent line to the equation x tan y = y - 1 at the point where y = pi/4. Participants clarify the differentiation process, using implicit differentiation and the product rule, leading to the expression dy/dx = -tan(y)/(x sec^2(y) - 1). There is confusion regarding the value of x, which is derived from the original equation, resulting in x = (pi/4 - 1). Ultimately, the correct slope can be calculated by substituting the values of x and y into the derived formula for dy/dx.
bondgirl007
Find the slope of the tangent line to x tan y = y - 1 when y = pi/4
I can't seem to get the derivative. Here's what I do.
First I used the product rule the left side of the equation and got sec^2 x dy/dx + tan y = dy/dx.
When I simplify, I get dy/dy over dy/dx, which just reduces to 1 so I'm having trouble with getting dy/dx on it own.
you miswrote it
x\sec^{2}y\frac{dy}{dx}+tan{y}=\frac{dy}{dx}
but either way you should have been able to algebraically solve for dy\dx
what would your next step be to find x?
I derived it and I got:
dy/dx = -tany/(xsec^2 - 1).
Is that the right derivative?
yeppp
Thanks for the help, people!
I need help with the tangent line now though. I have to find it when y = pi/4.
I'm not sure how to approach it because I don't have the value for x.
you can easily find it, you're given your y value. you also have your original equation, correct? where does the tangent line pass through?
It passes through pi/4.
Here's my equation:
dy/dx = -tan(pi/4)/(xsec^2 - 1)
I have two unknowns so not sure how to find it.
x\tan{y}=y-1 @ (x,\frac{\pi}{4})
For x, I got:
pi/4 - 1
When I find the slope and plug these in, I don't get what to do with the x and sec^2. Is x part of the sec or not?
that's not the X value i got, check it again
x=\frac{y-1}{\tan{y}}
the derivative is the slope of your tangent line at your (x,y) so once you find both of those, you can find \frac{dy}{dx}
Thanks for the reply. I solved for x and still got: pi/4 - 1.
I'm not sure how to get the derivative by subbing in for dy/dx. What should I do with the sec^2. Is x part of the sec^2 function or is it a coefficient?
lol I'm so sorry, had a dumb moment. \frac{\pi}{4}=1
i make too many mistakes!
y'=\frac{dy}{dx}=\frac{\tan{y}}{1-x\sec^{2}y} @ (x,y) = m = slope
I got the same as numerator as you for the derivative but my denominator is xsec^2 y - 1
it's equivalent
This is the reply for bond girl007
Solution:
xtany=y-1
differentiate the two sides of the equation:
d/dx(xtany) =d/dx(y-1) Lows of differentiation
tany+sec^2(y)dy/dx=dy/dx
make dy/dx in one side: tany=(1-sec^2y)dy/dx
using laws of trigonometrics: tany=(-tan^2y)dy/dx
we get: 1=-tanydy/dx
dy/dx=-1/tany
dy/dx=-1/tan(pi/4)
Hence: dy/dx=-1
ali1982 said:
Solution:
xtany=y-1
dy/dx=-1/tany
dy/dx=-1/tan(pi/4)
Hence: dy/dx=-1
[x\tan{y}=y-1] \neq [\frac{dy}{dx}=\sec^{2}y\frac{dy}{dx}+\tan{y}]
[x\tan{y}=y-1] \mbox{should equal, if I'm not mistaken b/c it's almost 2am} [x\sec^{2}y\frac{dy}{dx}+\tan{y}=\frac{dy}{dx}]
check please!
Indeed, ali1982 forgot the x in his equation. The result x=pi/4-1 is indeed correct. Now it is not difficult to find the slope. It is allready derived as dy/dx=tan(y)/[1-x*sec^2(y)]. The numbers x and y have been obtained, just put them in here. I think yo should get something like 2/(6-pi) approx. 0.7
thanYes, I forgot the x.When we differentiate, the term : sec^2ydy/dx must be multiplied by x ,and this term will be : xsec^2ydy/dx.
Thanks for correction.
  • · Replies 24 ·
