Hip
- 7
- 0
- TL;DR Summary
- A supply of negentropy into a system is necessary to create states of higher order and complexity. Since the origin and evolution of life involves the creation of ever more complex molecular arrangements of atoms, life could not start without a sufficient supply of negentropy. So when considering celestial environments where life might be created from scratch and continue evolving towards greater complexity, presumably only environments with a good negentropy supply would be viable candidates.
Summary: A supply of negentropy into a system is necessary to create states of higher order and complexity. Since the origin and evolution of life involves the creation of ever more complex molecular arrangements of atoms, life could not start without a sufficient supply of negentropy. So when considering celestial environments where life might be created from scratch and continue evolving towards greater complexity, presumably only environments with a good negentropy supply would be viable candidates.
The Earth's surface and atmosphere have an abundant supply of negative entropy (negentropy). This is because most of the energy the Earth receives from the Sun is in the form of near infrared, visible and ultraviolet light (which are relatively low in entropy), whereas the energy the Earth radiates back into space is mostly in the deep infrared range (which is high in entropy). Thus although the amount of energy the Earth radiates out is equal to the energy it receives from the Sun, the Earth constantly enjoys a net gain in negentropy.
Without this constant supply of negentropy, evolution of life on Earth could not have taken place (since evolution is an increase in order and complexity). And if Earth was also the place where life first began, then that initial creation of life would presumably also be dependent on negentropy (because I believe creating more complex molecules equates to an increase in order).
Refs:
Evolution and the Second Law
Steps Towards an Evolutionary Physics
Thus when considering whether life may have independently emerged in other environments in our solar system (on other planets or moons), presumably these places would only be good candidates for creating life if they have a constant supply of negentropy.
So for example, both Jupiter's moon Europa and Saturn's moon Enceladus have large underground oceans of liquid water, an ingredient considered essential for the creation of life. However, the oceans in Europa and Enceladus are thought to be heated not by sunlight, but rather by tidal flexing from their planets' strong gravity. Now I am not sure if energy received by tidal flexing results in any net gains in negentropy. And if there is no supply of negentropy entering into Europa and Enceladus, then I do not see much chance of any life emerging or evolving on these two moons.
But I'd be interested in hearing other people's views on this.
Refs:
