Impression of relative velocities
  • Context: High School
  • Thread starter Thread starter jishnu
    Relative
This discussion explores the perception of relative velocities while observing objects from a moving vehicle, focusing on how distance affects the apparent speed of nearby and distant objects. Participants share personal experiences and seek explanations for these observations, touching on concepts such as angular velocity and parallax.
  • Some participants note that objects closer to the observer appear to move faster than those farther away, attributing this to angular velocity, which depends on the ratio of speed to distance.
  • One participant suggests that the observer is the center of perceived rotation when considering how objects appear to move relative to their position.
  • A visual representation is provided to illustrate how the field of vision changes as the observer moves, showing that nearer objects shift more in the visual field compared to farther objects.
  • Some participants discuss the concept of perspective, questioning whether it explains why farther objects appear smaller and move slower in the observer's field of vision.
  • Parallax is introduced as a term that may explain the observed effects, with one participant suggesting further reading on the topic to understand its connection to the phenomenon.
  • A personal anecdote is shared about observing the Sun and trees while traveling, highlighting the difference in perceived motion based on distance.
Participants express various viewpoints on the relationship between distance, angular velocity, and perception of motion. There is no consensus on the best explanation, as some advocate for the concept of parallax while others focus on angular velocity and perspective.
Some participants mention the need for further exploration of terms like parallax and angular velocity, indicating that assumptions about these concepts may vary among contributors.
jishnu
Hi everyone,
This is just a random thought that popped up in my mind while I was traveling in train to my college
When we are inside a moving object and looking outside those thing that are near appears to move back(or move in opposite direction to that of our motion) with a same speed as ours but the farther object on the side(as seen through the window of the vehicle) seems to move a bit slower!
I have felt the same when looking to moon from a moving perspective, it seems the moon does not move.
I wonder how can these thing be explained!
The angular velocity of objects (how fast they move through your field of vision) depends on the ratio of their speed and their distance.
Near -> large angular velocity
Far -> small angular velocity
Could you make it more specific. Will I be right to take the centre of rotation as the far point that I look at when considering the point about which it rotates!
You are the center of the perceived rotation.
Ohk, now that make sense
Thank you[emoji3531]
For a visual representation, the black lines are your field of vision. Your motion is "downward" in the figure.
At first, both the distant and near object are in the center of your field of vision and along the same sight line.
At some moment later, you have moved to a new position relative to the objects as shown by the green arrow. The new sight lines to the objects are shown. Even though your relative motion and resultant shift in position relative to both objects is the same, the sight line to the nearer object has shifted more than the sight line to the further object. Extrapolating this forward and backward in time has the nearer object entering your field of vision well after, leaving it well before, and taking less time to cross your field of vision than the further object does.
jishnu said:
...the farther object on the side(as seen through the window of the vehicle) seems to move a bit slower...
Do you understand why farther objects look smaller? The distance they move per time looks smaller for the same reason.
This is more convincing and simple explanation
Thank you [emoji3531]
A.T. said:
Do you understand why farther object look smaller? The distance they move per time looks smaller for the same reason.
I guess that is because of the perspective,
I don't know whether I am right!
[emoji846]
jishnu said:
Hi everyone,
No one seems to have introduced the term "Parallax" yet. That's the normal way that these strange effects that we see when moving on trains etc.. A search on the term will give you plenty to think about and many explanations.
How parallax is getting connected with this phenomenon! [emoji848]
I suggest you read about parallax and then you will find out. It is the best explanation of the effect you get on a train and the same effect is used in calculating the distance to stars.
Good old Wiki will tell you all about it.
Janus's diagram also (nearly) shows why very distant objects such as the Sun or Moon do not appear to move at all. They are almost at infinity, so the line of sight remains in the same position. I remember asking my father this very question when I was small and staring out the car window. Trees flashed past but the Sun was steady. His correct explanation went over my head.:cry:
  • · Replies 53 ·
  • · Replies 61 ·
  • · Replies 17 ·
