Homework Helper
- 30,567
- 7,542
waynexk8 said:How do you work that out ? What machine can lift say 80% up, and then lower it down using very little energy, and what energy is this ?
Wayne
Where and how does the machine get its energy back ? It will be powered by say diesel or electricity, let’s say diesel, so it uses, let’s just say a half a pint of diesel to lift the weight, you tell me where and how the machine gets that diesel back ? You know very well that when the half a pint of diesel is gone, has been used to lift the weight, you can “never” get it back.
And when it lowers the weight, it will have to use energy again, as in the diesel, a little less this time, but it has to use energy/diesel to move in any direction, as its using force, and this force is putting tension on the machine.
You and all here know physics far better than me, but I give you 7 real World practical points proving your theory does not fit, and as you know, a theory, is just a theory until you can prove it with a practical experiment, and I have proved it wrong and few times.
Just for now take the EMG, and the fact that you fail 50% faster.
Also, what have you proved ? I see no equations, what you did say that there is no such thing as total/overall force in physics, yet the EMG reads out a higher average reading on the faster, and the EMG work with the equations of physics, they are put in the EMG.
I thought is was the physics job to do the theory, and when the practical proves this wrong, the physics needs to be looked at.
I do see what you mean, but what about my points, like the EMG, and the fact you fail faster, they can only mean one thing, the fast is putting more tension on the muscle, and the only way to put more tension on the muscle is by putting out more force, and taking more force on the muscles.
Wayne
Here you go again - leaping in with both feet in the absence of knowledge. Do you know the difference between a Machine and an Engine? Of course a diesel engine has no energy return but a Machine, consisting of no more than a SPRING can lift and lower a weight without losing any energy at all (allowing for a minuscule amount, due to friction.
You have got it wrong when you say it is up to us to Disprove what you say. I'm afraid that it is up to you to Prove what you say because it goes against all known Physics. Just read any simple textbook to find out the meanings and derivations the various terms that you are using with such abandon.
There is not a single statement from any of us which denies the fact that you feel more knackered and your muscles ache more when you are doing exercise faster. Our issue it that you are trying to 'explain' this in 'physics' terms that just don't apply. You have a gut feeling that it should be straightforward but you don't seem to realize just how muscles actually work. If you read what douglis tells you, instead of giving all those "but surely" - type responses then you might learn something.
Most people come on this forum in order to learn something. You have breezed in and you're trying to tell us all how we should be able to do something with the Physics that we understand but that you do not. Do you ever consider that you might just be plain wrong in this?
