Impulse, Momentum, and Baseball
The discussion focuses on the concepts of impulse and momentum in the context of baseball physics. A baseball with a mass of 0.145 kg experiences a change in momentum calculated as -14.5 kg*m/s when pitched at 45.0 m/s and hit back at 55.0 m/s. The impulse applied by the bat is equal to this change in momentum, confirming that impulse and momentum change are equivalent. Additionally, the average force exerted by the bat, given a contact time of 2.00 ms, is determined to be -7250 N, emphasizing the importance of understanding both magnitude and direction in these calculations.
  • Understanding of basic physics concepts such as momentum and impulse
  • Familiarity with the formula for change in momentum: delta p = m * delta v
  • Knowledge of force calculations using impulse: J = F * delta t
  • Ability to convert units, specifically milliseconds to seconds
  • Study the relationship between impulse and momentum in different contexts
  • Learn about the conservation of momentum in elastic and inelastic collisions
  • Explore advanced force calculations in physics, including average and instantaneous force
  • Investigate real-world applications of impulse and momentum in sports science
Students and educators in physics, sports scientists, and anyone interested in the mechanics of baseball and the principles of impulse and momentum.
Soaring Crane
A baseball has mass 0.145 kg.
A. If the velocity of a pitched ball has a magnitude of 45.0 m/s and the battered ball's velocity is 55.0 m/s in the opposite direction, find the magnitude of the change in momentum of the ball.
delta p = m*delta v = m*(v2 -v1) = .145 kg (-55.0 m/s - 45.0 m/s) = -14.5 kg*m/s
B. Find magnitude of impulse applied to it by bat.
J = F*delta t = delta p = -14.5 kg*m/s ?? Is it the same as the above?
C. If the ball remains in contact with the bat for 2.00 ms, find the magnitude of the average force applied by bat.
J = Avg. F*delta t
delta t = 2.00 ms(1s/1000 ms) = .002 s
Avg. F = J/delta t = (-14.5 kg*m/s)/.002 s = -7250 N ?
Thanks.
All good. (Since they ask for magnitudes only, your answers should be positive.) And yes, since impulse equals change in momentum, the answers to A and B are the same.
why should the answer be positive ? iam kind of confused I thought it depended on what velocity is positive and negative
It comes from the formula for magnitude - 2d = sqrt(x^2 + y^2). Even if x or y were negative, -x * -x = +x^2. There are no square roots of negative numbers (apart from complex numbers).
The answers should be positive, since they are asking for the magnitudes. The negative sign gives you the direction.
  • · Replies 19 ·
