Impulse on a water bag being dropped
  • Context: Graduate
  • Thread starter Thread starter abrewmaster
    Impulse Water
The discussion focuses on modeling the impulse experienced by a bag of fluid when dropped, emphasizing the role of fluid viscosity in the impact dynamics. The general impulse equation F∂t=∂P is referenced, alongside the viscosity equation η=F/A*t, highlighting the complexity introduced by the bag's nonuniform shape and changing area. Participants suggest that solving this problem may require the use of Navier-Stokes equations and finite element analysis software for both fluid and solid mechanics. Additionally, they recommend exploring existing models related to flood modeling and raindrop impacts for insights.
  • Understanding of fluid mechanics principles, particularly impulse and viscosity.
  • Familiarity with Navier-Stokes equations for fluid dynamics.
  • Knowledge of finite element analysis (FEA) software for modeling complex interactions.
  • Basic concepts in solid mechanics related to material deformation.
  • Research the Navier-Stokes equations and their applications in fluid mechanics.
  • Explore finite element analysis software options, such as ANSYS or COMSOL Multiphysics.
  • Investigate existing flood modeling techniques, particularly those involving dam burst scenarios.
  • Study the impact dynamics of raindrops on surfaces to draw parallels with the fluid bag scenario.
Researchers, engineers, and students in fluid mechanics, particularly those interested in impulse dynamics, viscosity effects, and modeling complex fluid-solid interactions.
abrewmaster
I have been trying to derive an equation to represent how a bag full of fluid would react when dropped dependent on the fluids viscosity. Basically i have the general impulse equation: F∂t=∂P but the time is dependent on the fluids viscosity (higher viscosity the longer it takes for the impact to finish) so I tried using the equation of viscosity: η=F/A*t but in this case of the equation I have a changing area that is dependent on the time as well as the dimensions of the bag. I don't have the slightest idea how to model this varying area since it is an nonuniform shape. Anyone have any ideas how to model this?
Hi abrewmaster. Welcome to Physics Forums.
This is a difficult fluid mechanics problem, and would probably require solution of the partial differential fluid mechanics equations (Navier Stokes equations) or turbulent flow approximations, even if the bag were assumed to be spherical and the deformation were assumed to be axisymmetric. You would also probably have to model the deformational mechanics of the bag, and its interaction with the fluid. I'm guessing that modeling this problem would require use of finite element fluid mechanics software coupled with finite element solid mechanics software. The moving boundaries would add even more complexity to the analysis.
I was afraid of something like that although I already knew that was probably the answer anyway. I will probably just make a lot of assumptions for something like this to save time during the calculations to get an estimate that makes sense and just work from there.
There may be a model already available for this type of problem. I see two situations that might have similarities. Firstly the impulse sound of rain drops falling on a hard surface, and secondly, flood modelling.
In flood modelling a sphere of water equal to a reservoir's volume is released at one point on the landscape to model the catastrophic failure of the containment structure. For the real world, finite element analysis is used for flood modelling, but the time scale needs to be checked against a simple theoretical model. That model would include viscosity. You might google { dam burst flood modelling } and trace references back to verification of the model.
Here are some thoughts along these lines. You can bound the answer by considering the maximum and minimum possible changes in momentum that can occur. After impact, the upward velocity can't be greater than the impact velocity, and it can't be less than zero (i.e., the ball sticking to the ground). So an upper bound to the impulse of the force is 2mv, and a lower bound is mv. Taking the average (1.5 mv) might be adequate for your purposes.
Chet
  • · Replies 46 ·
  • · Replies 17 ·
17K
