Impulse Problem: Find Mass, Height & Impulse
  • Thread starter Thread starter chocolatelover
    Impulse
The discussion centers on calculating the impulse experienced by a ball of mass 0.110 kg dropped from a height of 1.25 m that rebounds to a height of 0.800 m. The correct formula for impulse is identified as J = Δp, where J represents impulse. The user is advised to refine their approach by using the integral form J = ∫F dt for precise calculations, particularly as Δt approaches zero. The final calculation presented yields an impulse of -0.4876 Ns.
  • Understanding of impulse and momentum concepts
  • Familiarity with calculus, specifically integration
  • Knowledge of gravitational force calculations
  • Basic physics principles regarding motion and energy
  • Study the concept of impulse in detail, focusing on J = ∫F dt
  • Learn about the relationship between momentum and impulse
  • Explore advanced applications of calculus in physics problems
  • Investigate energy conservation principles in elastic and inelastic collisions
Students studying physics, particularly those focusing on mechanics and impulse, as well as educators looking for examples of impulse calculations in real-world scenarios.
chocolatelover
A ball of mass .110 kg is dropped from rest from a height of 1.25 m. It rebounds from the floor to reach a height of .800 m. What impulse was given to the ball by the floor?
I=ΣFΔt
Δp=I
Could someone please tell me if this is the correct formula?
Thank you very much
Hi chocolatelover! Both of your equations look right but need some minor tweaking.
For starters (I have no clue why, but...) the symbol for impulse is a capitol J.
So J = Δp for instance.
Your first equation should be extended a bit more.
J = ΣFΔt would give you an approximation for impulse however if you wanted the exact value of J you would need to make Δt -> 0, and sum up an infinite number tiny bits force.
A more concrete definition would be J = \int_{t_i}^{t_f}{F dt}
Thank you very much
Does this look right?
integral from 1.25 to .800 (.110kg)(9.8m/s^2)dt
=.8624-1.35
=-.4876
Thank you very much
  • · Replies 24 ·
