In-Depth Pascal's Law Explanation
Pascal's Law, also known as the principle of transmission of fluid-pressure, asserts that pressure applied to a confined incompressible fluid is transmitted undiminished in all directions. This principle is rooted in the conservation of energy and the incompressibility of fluids. The discussion highlights the importance of understanding pressure distribution within fluids, emphasizing that if pressure were not uniform, particles would accelerate in specific directions, which does not occur. The conversation clarifies misconceptions about pressure differences at various locations within a fluid.
  • Understanding of fluid mechanics principles
  • Familiarity with the concept of incompressibility in fluids
  • Basic knowledge of pressure and energy conservation
  • Ability to analyze physical systems involving pistons and fluid dynamics
  • Study the derivation of Pascal's Law in fluid mechanics
  • Explore applications of Pascal's Law in hydraulic systems
  • Learn about the implications of fluid incompressibility in engineering
  • Investigate pressure distribution in various fluid scenarios
Students and professionals in engineering, particularly those focused on fluid mechanics, hydraulic engineers, and anyone interested in the principles governing fluid behavior under pressure.
Von Neumann
Problem:
The general idea makes sense intuitively to me, but most sources I've found cite Pascal's Law merely as scientific fact with not much explanation. What I'm wondering is why pressure applied at one point in a fluid is transmitted undiminished to all other points? Is it a concept due to the inherent properties of fluids that I must simply accept?
Could probably derive it from conservation of energy and incompressibility of the fluid. Consider two pistons located within the fluid. The difference between work done expanding one and allowing the other to shrink by the same volume must be balanced by the net change in PE of the fluid.
If p were not the same in all directions then a particle would be accelerated in some direction, which doesn't happen.
I don't think that was the question. It's to do with pressures at different locations, not different directions.
Oh yes? "Pascal's law or the principle of transmission of fluid-pressure is a principle in fluid mechanics that states that pressure exerted anywhere in a confined incompressible fluid is transmitted equally in all directions throughout the fluid such that the pressure ratio (initial difference) remains the same.[1"
-wikipedia, italics mine.
If I go deeper I go to a different location where the pressure is not the same, is it ...
9K
  • · Replies 34 ·
