In how many seconds will the n-th wagon pass next to me?
The problem involves a train that starts to travel in a straight line at increasing speeds, with the first wagon passing a stationary observer in 4 seconds. The question is to determine how long it will take for the n-th wagon to pass the observer. The context includes concepts of motion, acceleration, and possibly sequences, though the original poster indicates a lack of familiarity with sequences.
  • Participants discuss the relationship between time and distance for the wagons, with some suggesting the use of kinematic equations. There are questions about the assumptions regarding acceleration and the interpretation of the problem's wording, particularly concerning the meaning of "increasing speeds" and the initial conditions of the train's position.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have provided clarifications about the assumptions regarding constant acceleration and the uniform length of the wagons. However, there is no explicit consensus on a method to derive the time for the n-th wagon, and participants are still questioning how to approach the problem effectively.
There are constraints regarding the initial position of the train relative to the observer, which remains unspecified. Additionally, participants note the ambiguity in the phrasing of the problem, particularly regarding whether the time refers to the entire wagon passing or just a point of the wagon.
HAF
Train starts to travel in a straight line at increasing speeds. The first wagon passes next to me in 4 seconds. In how many seconds will the n-th wagon pass next to me?
s= vo.t + 1/2at^2
v= vo + at
First of all we didn't learn sequences at school yet. That's why I try to solve it with these equations. Maybe the right question is "Is it solvable without knowing sequences?"
I tried to use the equation for velocity and compare then t1 with t2 with t3 and so on but there just so many unknowns and I can't figure anything out. Thank You I appreciate it.
This is similar to a free-fall scenario. In the first 4 seconds the distance is one train length, let's call that X. When do we get twice the distance (2X), which means the second wagon passed? You can express this with two equations and two unknowns or rearrange your first formula to use just a single equation.
Is that all it says? Nothing about constant acceleration, or maybe constant power?
I'm very sorry. I forgot to say that those wagons have same length.
And acceleration is constant you are right.
Please post the complete question.
Not difficult if you assume that "straight line" is not important, "increasing speeds" means "constant acceleration", and "The first wagon passes next to me in 4 seconds" means "At the start, I was standing at the front of the first wagon, which then passed me after 4 seconds", because you won't be able to solve it cleanly, otherwise.
Train starts to travel in a straight line at increasing speeds. The first wagon passes next to me in 4 seconds. Acceleration is constant and wagons have the same length. In how many seconds will the n-th wagon pass next to me?
It doesn't say how far away from you the train was when it started.
That's true. I was confused too but I take for granted what hmmm27 said.
No, it just means the acceleration has the same sign as the velocity.
But I know that acceleration is constant.
True : edited "take for granted" to "assume" in the post. Of course, the actual assumption is that a nice clean answer is expected, rather than one laden with offsets. Both assumptions are odd enough to be worth mentioning in the submission, though (which could be taken as doing the student's homework for them, for which I apologize).
hmmm27 said:
True : edited "take for granted" to "assume" in the post. Of course, the actual assumption is that a nice clean answer is expected, rather than one laden with offsets. Both assumptions are odd enough to be worth mentioning in the submission, though.
To me "the wagon passes next to me" means the centre of the wagon, which is a also a solvable problem.
Well, if you insist... it could be a Wild West wagon train, in which case we'd want to know the distance between the arse end of a wagon and the horse pulling the next one, as well... and of course the length of the average horse.
To me that means that it takes 4 seconds for the whole wagon to pass (from front to back). I guess the OP will need to make assumptions about the actual meaning.
So guys I talked to my teacher and he clarified few important things.
1. At the beginning I'm staying in front of the first wagon.
2. Wagons have the same length
3. Acceleration is constant.
Then you're all set :smile:
hmmm27 said:
Then you're all set [emoji2]
Yeah now I fully understand the problem. I found out the equation for every time by comparing time of first wagon, second wagon and third wagon.
Is there an easier way to find out the equation for time of the n-th wagon?
I'm entirely unsure how you'd find the time for the first, second, third wagon, without actually having a formula with an "n" in it. But, I'm lazy.
I thought about it this way.
s1=s2 and then again s1=s3.
It's also ambiguous in terms of whether you want the instantaneous time that (the end of) the nth wagon passes a given point; or, the length of time that the whole of the nth wagon takes to pass.
Oh, well that's clear:rolleyes:
Care to share ? in longhand... formulas and stuff.
I suppose that you need some unit of length. Right?
Each wagon is the same length, so 'wagon' could be the length unit, and wagon/sec velocity, and wagon/sec2 the acceleration unit.
Then use kinematic equations
May I ask something please?
How can I insert time(n) into those kinematic equations?
I would like to solve this problem as fast as it could be but comparing time(1) and time(2) and etc. Isn't fast enough.
I hope you won't get angry because of my question.
Thank You
Thank You
One of the problems is that you haven't shown us any of your work yet. We've no idea how you are trying to solve this problem, what your algebra skills are like and how you use the kinematic equations.
For example, suppose you were asked to find the speed of the train after the nth wagon has passed, then I would do something like:
Let ##L## be the length of each wagon.
We have the kinematic equation: ##v^2 - u^2 = 2as##, which in this case (##u = 0##) reduces to ##v^2 = 2as##, where ##a## is the constant acceleration of the train.
Let ##v_n## be the speed of the train after ##n## wagons have passed. Then we have:
##v_n^2 = 2a(nL)##
And, suppose you were given that the speed of the train after the first wagon was ##v_1 = 2m/s##, and the length of each wagon is ##16m##. Note: this is a different problem from your one. Then:
##v_1^2 = 2aL##
##a = \frac{v_1^2}{2L} = \frac{4m^2/s^2}{32m} = 0.125 ms^{-2}##
And, finally,
##v_n^2 = 2(0.125 ms^{-2})n(16m) = (4n)m^2s^{-2}##
##v_n = (2\sqrt{n}) ms^{-1}##
That's not necessarily the quickest way to solve the problem, but I wanted to illustrate the way you should be approaching these problems. How to introduce variables, and use and solve the kinematic equations.
This is how I worked.
As you said
PeroK said:
Let LL be the length of each wagon.
we know that L1 = L2 = Ln
t1 = 4 s
at the beginning we know that L1 = ½.a.t12 = L2 = L3
then I wrote equation L2 = v1.t2 + ½.a.t22 NOTE: v1 = a.t1
and L3 = v2.t3 + ½.a.t32 NOTE: v2 = a.t1 + a.t2
t2 = 4.(√2 - 1)
t3= 4.(√3 - √2)
and that's how I found out that tn = t1.[√n - √(n-1)]
But this way is very long i guess and I have no idea how to solve it faster.
Thank You for your help.
t1 = 4 s
t2 = 4.(√2 - 1)
t3= 4.(√3 - √2)
Okay, so you have interpreted the question as asking for the time that the nth wagon takes to pass. As I pointed out in post #22 the question was also ambiguous on this point. The alternative is that the question is asking for the total time for n wagons to pass.
If we let ##T_n## be the total time for n wagons to pass, then we have ##t_n = T_n - T_{n-1}##. And that should give you perhaps a quicker way.
That's the way I interpreted the question. I do agree that the ambiguous wording is confusing.
Can you please give me one more hint please?
10K
