In the early days of electricity, they didn't have wall plugs
The discussion revolves around the historical use of electrical appliances and the evolution of power outlets, particularly focusing on the early practice of using light sockets for powering devices instead of dedicated wall plugs. Participants explore the implications of this practice, the types of fittings used, and the transition to modern electrical systems.
  • Historical
  • Some participants note that early electrical appliances were often connected to light sockets, raising questions about the safety and practicality of this method.
  • One participant mentions the potential for damage to power cords when using Edison screw fittings, suggesting that bayonet fittings may have been less damaging.
  • Another participant recalls the limited availability of power points in the UK during the 1940s and the use of bayonet fittings for appliances like electric irons.
  • There is a mention of the evolution of electrical systems post-World War II, including the introduction of ring circuits and safety plugs.
  • Some participants discuss the standardization of lamp fittings and how they became a de facto standard for electrical connections while traveling.
  • A humorous exchange occurs regarding the concept of a virtual waterfall in a laundry room, leading to discussions about the feasibility of using such a setup for laundry appliances.
  • Participants debate the grounding capabilities of screw-in adapters, with some asserting that modern adapters do not provide grounding and others suggesting modifications could be made to accommodate grounding.
  • There are anecdotes shared about personal experiences with screw-in adapters and their reliability, including a story about a grandmother's washing machine that only worked under certain conditions.
Participants express a range of views on the historical use of light sockets and the safety of various fittings. There is no clear consensus on the effectiveness or safety of screw-in adapters, and discussions about grounding remain unresolved.
Participants highlight the limitations of early electrical systems, including the absence of standardized power outlets and grounding methods, which may have influenced the practices discussed.
DDTJRAC
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff!
Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use?
1906 ad DDTJRAC
American%20Vibrator%20Co.%201906%20D.D.T
Even big washing machines were screwed into the socket.
1909 ad DDTJRAC
1900%20Washer%20Co.%20ad%201909%20D.D.Te
This machine was also water powered. Don't know how well that worked. Wow, all the wasted water!
Edited just now by Daniel D. Teoli Jr.
Science news on Phys.org
I expect the use of Edison screw, ES, or E27 light fittings would twist and damage the power cord. Maybe bayonet cap lamps, BC, or B22, did less damage to the cords, and so extended the time before general purpose outlets became available.
Also, there were some with a gasoline engine...
Here's a video some here might find interesting. It's an hour long, but it's fun I guess.
If you want to skip to the part about people just screwing all their appliances into the overhead socket, skip to 11:00 timestamp (right after the electric tablecloth section).
They start talking about very early sockets at around the 18:00 timestamp.
I remember that in the 1940s in the UK, we had power points, but very few. The bayonet light fitting was often used for electric irons. After WW2 the electrical systems were modernised with the introduction of ring circuits and the special safety plug we still have today.
I also remember and using 2-way adapters for bayonet fittings, so you could have a light bulb and a power take off. No earth pin of course.
Power points were not initially standardised or widespread. As light globes became a commodity, a national lamp globe standard emerged, Edison Screw with coaxial terminals in the USA, bayonet, with two contacts in the UK. When travelling nationally, the lamp fitting became the more reliable de facto standard.
DDTJRAC said:
In the early days of electricity, they didn't have wall plugs​
For some reason, this reminds me: Before the crowbar was invented, crows had to drink at home.
Ha! That would be a fun thread.
I live in Oregon, where we get 34% of our electric needs from hydroelectric plants.
I signed up for 100% renewable several years ago, so I think my 'wasted water' is around 70%.
Anyone know how to use these new AI thingys to display a waterfall powered generator in my laundry room to machine wash and dry just one load?
as always, ok to delete, infract and ban
You have a waterfall in your laundry room ?
No, I have a virtual waterfall in my laundry room.
So, you're going to get virtual electricity to power your washer dryer? This all sounds very suspicious :smile:
Growing up in an older house in the 1940's and 50's we used screw in adapters. Not what the OP had in mind but they were widely used. They are still available. They didn't have a third ground wire way back then.
I don't think those modern adapters have a ground wire either. I've never seen a light socket that could accommodate any additional wire connections beyond hot and neutral. After all, light sockets are intended for standard E26 light bulbs, none of which have a ground connection.
Sockets for three way lights can:
OK, that's a fair observation. But for those sockets, to which terminal would it be proper to connect a green (in the US) ground wire? And since the adapters shown in post #14 only appear to have two contacts (an outer threaded one and a centered smooth one) how can that ground be passed through to the plugged-in device?
There are one neutral and two hot contacts. This gives you the threeway-ness:
  1. Neutral vs. hot 1
  2. Neutral vs. hot 2
  3. Neutral vs. hot 1 and hot 2
One of the hots could be wired as a ground instead of another hot.
You would also need a screw in to normal three prong socket adapter (there's probably a name for that) to use the whole set-up as something to plug into.
How the screw-in socket would be wired (by you) would be determined by the purchased product you plan on using with it.
Or you could make your own adapter.
You could check items out at on-line electronics suppliers or local electrical supply stores (they have guys in there to talk to).
Agreed, one could modify a standard two-terminal light socket to accommodate a ground terminal and make an adapter that would then provide a ground to a 3-prong/polarized outlet.
But the intent of my post #15 was simply to point out that it's quite unlikely that the commercial adapters shown in post #14 are actually grounded. Instead, the outlets shown are likely designed merely to accept the prongs of a standard plug mechanically without providing any electrical grounding.
Do a search.. You may find something.
About 1980, my grandmother had her wash machine plugged into one of these adaptors. I asked her if that really worked, and she said that it only smoked during a heavy load. So we had a work party the following weekend. My father, brother in law, and I completely rewired her basement with grounded outlets and a light switch at the top of the stairs.
  • Care
  • Sticky
  • · Replies 705 ·
24
122K
