Inclined plane and elapsed time
10 replies · 6K views
Sassenav22
A block is given a initial speed of 5.0 m/s up the 20° plane. (a) How far up the plane will it go?
(b) how much much time elapses before it returns to its starting point?
I think
V= u + at
s=ut t 1/2at^2
v=d/t
(a) V= u + at
0= 5-9.8(sin20)t
t = 1.65s
s=ut+1/2at^2
=5(sin20)(1.65)+ 1/2(9.8)(1.65^2)
s= 16.16m
(b) v=d/t
t=d/v
=16.16/5
t= 3.2s
I know this is wrong but i can't figure it out can someone help me?
Sassenav22 said:
V= u + at
0= 5-9.8(sin20)t
t = 1.65s
Recheck your arithmetic. (Tip: Once you've solved for the time the block takes to rise, what's the answer to part b?)
s=ut+1/2at^2
s= 16.16m
The initial speed up the ramp is already parallel to the incline, so there's no need to multiply it by sin20. On the other hand, the acceleration along the incline is only a component of g, so you do need the sin20 there. Also, should the acceleration be + or -?
So what your saying is that the sin20 is suppose to beby the 9.8?
Sassenav22 said:
acceleration should be positive
No. The ramp slopes up, so acceleration is negative (down).
Yes, the acceleration of the block is g sin20.
Oh, Is the first part of (a) correct because I found the time so that i could find the distance, is that what is suppose to be done?
Yes, that's a perfectly fine way to solve the problem. You just made an error when you did the final arithmetic to solve for the time.
so its:
(a) V=u+at
0=5+9.8(sin20)t
t = 1.65s
s= ut+1/2at^2
= 5(1.65)+1/2(-9.8)(sin20)(1.65^2)
=3.69m
(b) v=d/t
5=3.69t
t=3.39/5
t=0.68s
Sassenav22 said:
(a) V=u+at
0=5+9.8(sin20)t
t = 1.65s
The final answer is still wrong. Redo the calculation.
s= ut+1/2at^2
=3.69m
You'll need to redo this with the correct time.
(b) v=d/t
5=3.69t
t=3.39/5
t=0.68s
No. Read my "tip" in post #2.
v=u+at
= 5-9.8(sin20)t
t= 1.64s
I still get the same answer
Sassenav22 said:
v=u+at
= 5-9.8(sin20)t
t= 1.64s
I'm curious how. t = 5/(9.8sin20) = ??
