Increase dielectric strength of a cylindrical capacitor
The forum discussion focuses on increasing the dielectric strength of a coaxial cylindrical capacitor designed for 5 kV at 10 kHz, which experiences breakdown when subjected to 10 kV at the same frequency. Key solutions proposed include coating the copper tubes with copper oxide (CuO) to enhance dielectric strength, using nitric acid to increase the gap distance, and replacing copper with zinc tubes. Additionally, the impact of the Paschen Curve on vacuum conditions and the feasibility of using alternative dielectrics such as oil or plastic were discussed as potential methods to improve performance.
  • Understanding of coaxial capacitor design and operation
  • Familiarity with dielectric materials and their properties
  • Knowledge of the Paschen Curve and its implications for breakdown voltage
  • Basic principles of electrochemistry related to oxide formation
  • Research the properties and applications of copper oxide (CuO) as a dielectric material
  • Explore the effects of different dielectric materials, such as transformer oil, on capacitor performance
  • Investigate the Paschen Curve and its relevance to vacuum conditions in electrical components
  • Study the impact of varying conductor materials on capacitance and dielectric strength
Electrical engineers, capacitor designers, and researchers in materials science focused on improving dielectric strength and performance of capacitors in high-voltage applications.
gao7857
You have a co-axial cylindrical capacitor placed in vacuum. The two co-axial cylinder tubes are made of copper. The outside tube radius a1 and inside tube radius a2, with overlapping length L; both tubes have a thickness of t. Say, the capacitor was designed to withstand 5 kV voltage at 10 kHz. Now you are applying 10 kV at same 10 kHz, and you see a breakdown. Assume a1, a2 and L are fixed. The question is: How can you make the capacitor work for 10 kV at 10 kHz?
C=epsilon*A/d
(1) dip the capacitor tubes in sodium hydroxide, then oven-heat it, to turn surface copper into a thin layer of copper oxide (CuO). CuO has larger dielectric strength, so it can withstand higher voltage. Issue: CuO has larger permittivity and will this affect the frequency transmission?
(2) dip the capacitor tubes in nitric acid, to remove a thin layer of the copper, so the gap distance between two cylinders increased a little, affording a larger voltage.
(3) coat the tubes with a thin layer of zinc. Similar idea as in attempt (1).
C=epsilon*A/d
I think you are on the right track with the coatings.
Also, the use of the term "vacuum" in the problem statement is a bit vague. Think about how the Paschen Curve can have an effect...
http://en.wikipedia.org/wiki/Paschen_curve
Thanks Berkeman,
You are right about the Paschen curve. I should say that the vacuum is at the lower end of the curve. (say, an other attempt could be to adjust the vacuum to either a small tor or a higher pressure with an inert gas, if the original vacuum was not at the optional level)
I have another thought. How about change the material from copper to zinc: repalce the copper tubes with zinc tubes?
Thanks,
gao
gao7857 said:
Thanks Berkeman,
Thanks,
gao
The idea of oxide growth is analogous to the electrolytic capacitor, though in the electrolytic the oxide insulator/dielectric is continually maintained by electrolytic action.
It seems to me that this self-maintenance function would be absent with the CuO layer, though beyond that I offer no opinion.
Is an oil or plastic or porcelain dielectric not feasible?
How would changing the conductor change things?
Do you have an oil in your mind?
Basically, the capacitor, which was designed for 5 kV 10 kHz, is expect to work for 10 kV 10 kHz.
Another question, if add/change material (oil dielectric or zinc coating or CuO coating or zinc tube), will the signal/frequency transmission be affected (e.g. out of phase)? What else will change?
Thanks
I don't have a particular oil or synthetic fluid in mind, so with no better leads to go on, if I had to I'd look at transformer oil and see what its properties are, then proceed from there. Whatever you add will increase the capacitance, though this is probably inconsequential.
10 kHz is audio frequency. What property would you hope may change were you to provide a different metal either side of the gap? Do you have any equations relevant to the task that reflect a different value for different metals?
As it stands, the air gap is withstanding 5kV and you need something else to withstand the other 5kV. I can't see a thin oxide/chemical layer withstanding even a few hundred volts.
I've been out of electrical power for many years, so take what I say as not even worth the paper it's written on. :shy: Have you googled for liquid dielectrics? It makes it easy when all you are concerned with is dielectric strength, as here, with no concern for permittivity.
I'd be interested in knowing how many uF a practical 5kV concentric cylinder capacitor like this can be expected to have, and to what use it would be put. Is the "attempted solution" something you came up with, or is it integral to the problem?
Have you worked out how wide the gap would be in a vacuum to just withstand 5kV? This would give you a feel for the dimensions you are dealing with.
