Indefinite Integral Question; e^x
24 replies · 5K views · last reply
Celadon
Find the indefinite integral (preferably using u-substitution):
∫(ex-e-x)2 dx
N/A
To be honest, I'm slightly confused as to which path I'm supposed to take with this, especially since I'm not sure what I should be using u to substitute here. This is one of my attempts at solving the question:
∫[(ex-e-x)2 dx]
= ∫[e2x dx] - ∫[e-2x dx]
= (e2x / 2) + (1 / 2e2x) + C
Could someone please tell me if I have the right answer / I'm on the right track / I'm completely wrong? If the latter, I'd appreciate it if you could help get me on track!
Thanks in advance!
You almost got it. But you've forgotten the cross-terms when you did the square.
There is a good substitution you could use instead. But your method is just as good.
Edit: p.s. welcome to physicsforums, your name is good. reminds me of the town in pokemon
If you need the u-substitution, try just putting u=ex.
(Remember that 1/a is the same as a-1)
EDIT: Also in your attempt you should also have
∫e2x dx + ∫e-2x dx +∫2 dx
Before I continue asking questions, thanks for all the help! I really do appreciate it and I'm sorry if I'm a bit slow, haha.
Now then...
@BruceW: Thanks for the help, the welcome, and the name compliment! I'm actually a fan of the colour itself and the city in Pokemon, heh.
@rock.freak667: Ugh, how could I forget 1/a = a-1? Thanks for the reminder. I have a question about the +∫2 dx, though. How exactly did it get there?
I think I'm actually a bit more confused than I initially thought I was. Let's say I went with this method:
u=ex
du=exdx ; dx=du/ex
...and then what? This is what I'm leaning towards:
=∫(u2 dx) - ∫(1/u2 dx)
Do I substitute dx for du/ex or am I over-complicating things? Oh man, my head's going to burst. @@
(ex-e-x)2 = (ex-e-x)(ex-e-x)
Multiply it out. (Use FOIL, if that's what you're used to.)
(e^x-e^(-x))^2=(e^x-e^(-x))*(e^x-e^(-x)). Multiply that out and you'll see where the '2' came from. rock.freak667 had the sign wrong on it.
Okay, do I tried expanding it and then went through this:
(ex-e-x)2 = (ex-e-x)(ex-e-x) = e2x + e-2x
∫(e2x + e-2x) dx
u = e2x
du = (e2x / 2) dx
Final solution:
(u2/e2x) + (2 / e2x)ln|e2x|
No, this is incorrect, as Sammy and Dick pointed out. (a - b)2 ≠ a2 - b2, which is essentially what you are doing.
When you expand (ex - e-x)2 you should get three terms, not two.
Also, there is an error below - you shouldn't get any log terms.
Celadon said:
∫(e2x + e-2x) dx
u = e2x
du = (e2x / 2) dx
Final solution:
Oh I see it now.
(ex - e-x)(ex - e-x) = e2x - 2 + e-2x
I somehow wrote "+ e0 - e0" at some point, oops. Thanks!
Time to try again. (:
For you last error, I think this is what you did:
∫dx/e2x = ln|e2x|
That is incorrect. Don't write the integrand as a fraction - use the negative exponents.
Okay, another attempt. Hope I fixed more than I broke, this time. :/
Thanks again everyone, I'm sorry for bothering you all. D:
∫(ex-e-x)2dx = ∫(e2x-2+e-2x)dx
= ∫e2xdx + ∫e-2xdx - ∫2dx
Let u = ex
du = exdx
∫e2xdx + ∫e-2xdx - ∫2dx = (1/ex)(u3/3)+(1/ex)(u-1/-1)-2x+C
= (1/ex)[(u3/3)+(u-1/-1)]-2x+C
= (1/ex)[(e3x/3) - (1/ex)]-2x+C
= (1/ex)[(e4x-3)/(3ex)]-2x+C
= [(e4x-3)/(3e2x)]-2x+C
Let u = ex
du = exdx
What is [itex]\displaystyle\int du \,?[/itex]
ex+C?
Celadon said:
ex+C?
Ignore my last post.
If u = ex and du = exdx,
then [itex]\displaystyle\int e^{2x}dx[/itex] becomes what integral in terms of u ?
∫u2dx? :x
[EDIT] Another attempt:
2e2x-2x-2e-2x+C
x_x
Celadon said:
∫u2dx? :x
I think I'm confused as to what happens with du. ._.
If du = exdx, then dx = du(1/ex), so:
(1/ex)∫u2du?
Yes. You appear to be confused.
You can't take 1/ex out of the integral. In fact you should leave it inside the integral as 1/u .
What is u2/u ?
What is u2/u ?
u1 or just u? xD
(also, I edited my previous post with another answer in case you missed it.)
Celadon said:
u1 or just u? xD
OK, so what is [itex]\displaystyle\int u \,du \,?[/itex]
Celadon said:
(u2)/2? :x
What does the ":x" mean ?
Just an emoticon; I add them to a lot of my sentences out of habit, haha... Sorry.
Okay so, I tried it again like this:
u=ex
du=exdx
dx=du(1/ex)
∫u2dx-2x+∫u-2dx = ∫u2(1/u)du-2x+∫u-2(1/u)du
=∫udu - 2x + ∫u-3du
=u2/2 - 2x + (u-2/-2) + C
=u2/2 - 2x - 1/(2u2) + C
=e2x/2 - 2x - 1/(2e2x) + C
u=ex
du=exdx
dx=du(1/ex)
=∫udu - 2x + ∫u-3du
Correct.
It would likely be expressed in a manner closer to the given problem.
e2x/2 - 2x - e-2x/2 + C
or
(e2x - e-2x)/2 - 2x + C
SammyS said:
Correct.
or
Thank you very much for all your help! I can finally move on and not worry about this one question anymore. The sense of relief from when you solve a math problem.. words can't describe it.
I really do appreciate your help. :D
just to add one last thing: I think the substitution that was hinted was the hyperbolic function, because that makes the integral nice and simple. But your way is good as well.
Edit: actually, its not much more simple. It just depends if you are more comfortable with sinusoids or exponentials.
Celadon said:
(u2)/2? :x
Celadon, that's not a good idea in a mathematics context, especially when x already has a meaning. You don't want to put anything in that prevents someone from understanding what you're trying to say.
