Indefinite Integration by u-sub/trig sub
wick3dgt
Integrate (x^3)sqrt(1-x^2)
I used trig. substitution along with u substitution and came up with (x^4)/4 +C which I know is wrong. My professor gave the answer -(((3x^2)+2)((1-x^2)^(3/2)))/15 . Please help!
Is there a special restriction in the question that says you can't use integration by parts?
The substitution you want is u=1-x^2. One x from the x^3 will then be used to create the du leaving x^2 but then you'll remember that x^2=1-u. Try it, you'll like it!
Which substitution? x=sin theta should work fine.
Ok I worked through it for you.
\int \frac{x^3}{\sqrt{1-x^2}} dx
x=sin theta
dx=cos theta d(theta)
\int \frac{x^3}{\sqrt{1-x^2}} dx = \int \sin^3 \theta d\theta
=\int \sin^2 \theta \cdot \sin \theta d\theta = \int (1-\cos^2 \theta)\sin \theta d\theta = \int \sin \theta d\theta - \int \cos^2 \theta \sin \theta d\theta
First integral is just -cos theta, 2nd integral is simple with u=cos theta. Easy as pi.
Yep - I get the Prof's result too.
First substitution: u= x^2
Second substition: let v^2 = 1-u
You should wind up with an integral of:
I = \int (v^4-v^2) dv
x=sin theta
Only if it were that simple. The radical is in the numerator. :wink:
I can't read. Kill me. I'll get another solution for you tomorrow then, for the right problem :P
Ok actually no problem either way.
Same substitution, x=sin theta
dx= cos theta d(theta)
\int x^3 \sqrt{1-x^2} dx = \int \sin^3 \theta \cos^2 \theta d\theta = \int \sin \theta (1-\cos^2 \theta)\cos^2 \theta d\theta = \int (\cos^2 \theta - \cos^4 \theta) \sin \theta d\theta Which is very simple with the easy substitution, u=cos x.
EDIT: Rewritten in the form \int (\cos^4 \theta - \cos^2 \theta) (-\sin \theta) d\theta it becomes what TheoMcCloskey said it would be.
But as Dick and ThomasMcCloskey (indirectly) said, The substitution u= 1-x2 is simpler.
