Index of Refraction: n1 * sin(theta1) = n2 * sin(theta2)
The discussion focuses on calculating the index of refraction (n1) of an unknown liquid using Snell's Law, specifically the equation n1 * sin(θ1) = n2 * sin(θ2). The light beam, emitted 8.0 cm below the surface and striking the surface 7.0 cm away, is totally internally reflected at an angle of 41.2°. The calculated minimum value of n1 is 1.5, indicating that the actual index of refraction could be equal to or greater than this value. The critical angle is emphasized as a key factor in determining the refractive index.
  • Understanding of Snell's Law and its application in optics
  • Knowledge of critical angles and total internal reflection
  • Basic trigonometry, including sine and tangent functions
  • Familiarity with the concept of refractive index
  • Research the derivation and applications of Snell's Law in different media
  • Study the concept of critical angles and their significance in optics
  • Explore the implications of total internal reflection in fiber optics
  • Investigate methods for measuring the refractive index of various liquids
Students studying optics, physics educators, and professionals in fields related to optical engineering and materials science.
Moony-
A beam of light is emitted 8.0 cm below the surface of an unknown liquid. The light beam is angled in a way that it strikes the surface 7.0 cm from the point directly above the light source. The light beam is totally internally reflected. What is the index of refraction of the unknown liquid?
n1sinΘ1° = n2sinΘ2°
n = c/velocity in medium
tanΘ = 7/8
Θ = 41.8°
Attempt 1:
n1sin41.2° = n1sin41.2°
Cancels out...
Attempt 2:
n1sinΘ° = 1sin90°
Two variables!
Attempt 3:
n1sin41.2° = 1sin90°
n1 = 1.518166
n1 = 1.5
Could do this, although I don't even know whether it is correct, since it does not use the actual critical angle.
Attempt 2:
n1sinΘ° = 1sin90°
Two variables!
Here angle is 41.2 degree. That itself is the critical angle. Find n1.
rl.bhat said:
Attempt 2:
n1sinΘ° = 1sin90°
Two variables!
Can you assume that for sure, though? It could be that the 41.2° is bigger than the actual critical angle, which is why it reflects... =|
Even if the angle of incidence slightly more than critical angle, the light will be totally internally reflected. If the angle 41.2 degree is more than critical angle, it is not possible to determine the refractive index of the medium.
So that would mean that there's no guarantee whether 41.2° really is the critical angle? And Attempt 3 would only work if 41.2° is the critical angle, right?[/size]
Yes. Bur in your attempt 3, how did you get the value of n1= .02?
Ah, sorry. I made a little calculator mistake with brackets... No wonder the value for n1 looked odd...
You have calculated that when angle of incidence is 41.2 deg, then the light is totally internally reflected. But it is impossible to know from the given data what will happen if angle of incidence is less than 41.2 deg. This means that we cannot know the exact critical angle. At the most we can say that it is not more than 41.2 deg.
Therefore the answer you got in the third attempt (i.e. 1.5) is the minimum possible value of n. Actual value may be equal to this or more than.
Can you find why 1.5 is the minimum possible value? Why not maximum?
