Induced current in a circular loop
30 replies · 6K views · last reply
DrZoidberg said:
If there is no solid core you can move the voltmeter above the coil and get a voltage that's somewhere in between +4.17 and -0.83 or -4.17 and + 0.83 depending on which way around you connected the meter. At some point it will read 0 but that point is probably not exactly above the coil because the setup is not symmetric since the two resistances are different.
Well I have studied the circuit using surface charge feedback mechanism too..My calculations for voltmeter reading match for both the cases (left and right side) with those done using your suggested method..:smile::smile: Exactly above the coil, the voltmeter will read 1.67 V, not 0 ,as you correctly predicted using the symmetry argument:smile:..Thanks again for your help..
