Induced EMF, bar moving through magnetic field
The discussion focuses on the induced electromotive force (EMF) in a metal bar moving through a magnetic field generated by a straight wire carrying a constant current I. The relevant equations include the magnetic field B given by B=μI/2πr and the motional EMF expressed as EMF=Blv. The participants derive the EMF by integrating the magnetic field over the length of the bar and confirm that point 'a' is at a higher potential than point 'b' due to the movement of positive charges towards point 'a' as determined by the right-hand rule.
  • Understanding of electromagnetic principles, specifically induced EMF.
  • Familiarity with the Biot-Savart Law and its application to straight wires.
  • Knowledge of the right-hand rule for determining the direction of magnetic forces.
  • Ability to perform calculus operations, including integration.
  • Study the derivation of the Biot-Savart Law for magnetic fields around current-carrying wires.
  • Learn about the applications of the motional EMF formula EMF=Blv in practical scenarios.
  • Explore the implications of the right-hand rule in various electromagnetic contexts.
  • Investigate the effects of varying current I on the induced EMF in conductive materials.
Students and educators in physics, electrical engineers, and anyone interested in understanding the principles of electromagnetism and induced EMF in conductive materials.
timnswede
A long, straight wire as shown below carries a constant current I. A metal bar with length L is moving at a constant velocity V as shown. Point ‘a’ is a distance ‘d’ from the wire. a) Derive an expression for the EMF induced in the bar. b) Which point ‘a’ or ‘b’ is at a higher potential?
B=μI/2πr for a straight wire. EMF=Blv for motional EMF.
For part a) I split up the bar into a bunch of small segments of length dr, a distance "r" away from the wire. so dB=μIdr/2πr. Integrating that from point (a) to point (a+b) I get B=(μI/2π)ln((a+b)/a). While I feel reasonably confident about that part, I thought about it a bit more, and I am not sure how multiplying the B-field, μI/2πr by the length, dr, really makes sense, am I forgetting something important? But assuming that is right, I just plug that into EMF=Blv, and get my answer.
Part b) I feel stuck on, only thing I could thing of was using the equation B=μI/2πr and plugging in and (a) and (a+b) for r. Since if I plug in (a) it will be a greater value, then the EMF will be greater there.
The B field is not segmented into small sections dB. B is not a differential here.
Do you know the Blv law? It's the expression for emf of a bar of length l moving with velocity v perpendicularly to a B field such that B, l and v are all orthogonal to each other. Now, what is the right expression for a differential element of emf based on this law?
I worked on it some more and got d(EMF)=B(r)vdr which simplifies to d(EMF)=(μI/2πr)vdr, with limits for the right side of "a" to "a+b". Also B(r) is the B-field a distance "r" away from the wire.
Forgot to add that for part b) I used the right hand rule and got the the magnetic force, Fb is pointing towards point a for a positive charge inside the rod, so the positive charges will go towards point a and the negative charges towards point b, so point a is at a higher potential.
That looks 100% right.
Great, thanks!
  • · Replies 41 ·
