What is the amplitude of induced EMF in a magnetic dipole antenna?
The amplitude of the induced EMF in a magnetic dipole antenna with 50 turns and a radius of 5.0 cm, exposed to an electromagnetic wave of frequency 870 kHz and electric field amplitude 0.50 V/m, can be calculated using the formula $$emf = -N\frac{\Delta \Phi}{\Delta t}$$. The solution involves determining the change in magnetic flux over time, which incorporates the magnetic field amplitude of 1.7 x 10-9 T. For an electric dipole antenna of length 5.0 cm aligned with the electric field, the induced EMF is calculated using $$\mathcal{E} = E \cdot L$$, where E is the electric field strength.
  • Understanding of electromagnetic wave properties
  • Familiarity with magnetic dipole antennas
  • Knowledge of Faraday's law of electromagnetic induction
  • Basic calculus for differentiation of sinusoidal functions
  • Study the principles of electromagnetic wave propagation
  • Learn about the applications of magnetic dipole antennas in communication systems
  • Explore the derivation of Faraday's law and its applications
  • Investigate the relationship between electric and magnetic fields in electromagnetic waves
Electrical engineers, physics students, and professionals involved in antenna design and electromagnetic theory will benefit from this discussion.
midgic
1. A magnetic dipole antenna is used to detect an electromagnetic wave. The antenna is a coil of 50 turns with radius 5.0 cm. The EM wave has frequency 870 kHz, electric field amplitude 0.50 V/m, and magnetic field amplitude 1.7 X 10-9 T.
(b) Assuming it is aligned correctly, what is the amplitude of the induced emf in the coil? (Since the wavelength of this wave is much larger than 5.0 cm, it can be assumed that at any instant the fields are uniform within the coil.)
(c) What is the amplitude of the emf induced in an electric dipole antenna of length 5.0 cm aligned with the electric field of the wave?
(b) $$emf = -N\frac{\Delta \Phi}{\Delta t}$$
$$\Phi = B \times A$$
(c) ?
(b) The frequency is 870 kHz, so one oscillation takes a time of $$1.15\times 10^{-6}~s$$
$$\frac{\Delta \Phi}{\Delta t}= \frac{\Delta B}{\Delta t}~\times A = \frac{(2)(1.7\times 10^{-9}~T)}{(\frac{1}{2})(1.15\times 10^{-6}~s)}~\times \pi~(0.050~m)^2$$
Would this be the way to find $$\frac{\Delta \Phi}{\Delta t}$$
(c) I'm not sure where to start.
Thanks for your help.
For ## \frac{\Delta{\Phi}}{\Delta t}##, ## B=B_o \cos(\omega t) ##, so that ## \frac{dB}{dt}=-\omega \sin(\omega t) =\omega \cos(\omega t+\pi/2) ##, where ## \omega=2 \pi f ##. The factor ## \omega ## is the correct factor to use here. Using ## f=\frac{1}{T} ## will be missing the ## 2 \pi ## factor. ## \\ ## And (c) is simple. You just need to convert ## L=5.0## cm to meters. They give you the electric field ## E ## for the electromagnetic wave. The EMF for that case is ## \mathcal{E}=\int E \cdot dl=E L ##.
Thank you so much for your reply. That makes sense for part (b).
I think I can write it like this: (?)
$$B = B_0~cos(\omega~t)$$
$$\frac{dB}{dt} = -B_0~\omega~sin(\omega~t)$$
Then $$emf = -N~B_0~(2\pi~f) \times \pi~r^2$$
And for part (c)...well as you point out, that's quite straight-forward. I should have been able to do that one.
Thanks very much for your help.
They just want the amplitude for part (b) so don't include the minus sign in the answer for the amplitude of the EMF. The minus sign is just the result of a phase shift.
