Inductance and Charge Redistribution
67 replies · 7K views · last reply
Ayesha02
Two fixed identical metallic spheres A and B of radius R=50cm each are placed on a non-conducting plane at a very large distance from each other and they are connected by a coil of inductance L=9mH as shown in figure. One of the spheres (say A) is imparted an initial charge and the other is kept uncharged. The switch S is closed at t=0. After what minimum time t does the charge on the first sphere decrease to half of its initial value ?
Loop law: kq/r- L di/dt -kq/r=0
where L is inductance, q is initial charge on spheres.
I tried applying loop law but I am not really sure we don't really have a closed loop here.
I guess they're testing some concept here that I'm not very good at (Why do i keep coming back to mutual inductance for some reason:|)
Any help will be appreciated:)
  • Circuit diagram of two spheres labeled A and B on a horizontal line, connected by an inductor labeled L in series with a switch labeled S.
Kirchhoff's loop rule has to do with adding up changes in potential around a closed loop (so there are actually two oddities with the 'loop law' in your relevant equations: ##\frac{kq}{r}## is a potential and not a potential difference :wink:); though I guess you could consider a closed loop to infinity and back in which case your construction is nearly correct.
Instead, suppose a current ##i## is flowing from sphere A to sphere B through the inductor, and that the charges of the spheres at any given time ##t## are ##Q_A(t)## and ##Q_B(t)##. What is the potential difference across the inductor: can you find two different ways of writing this, and equate them? How do you relate ##i## to ##Q_A(t)## and/or ##Q_B(t)##? How do you relate ##Q_A(t)## and ##Q_B(t)## to the total charge in the system, in order to eliminate one of them?
A few things to think about there...
etotheipi said:
Kirchhoff's loop rule is not going to help you here; that has to do with adding up changes in potential around a closed loop (so there are actually two problems with the 'loop law' in your relevant equations: ##\frac{kq}{r}## is a potential and not a potential difference :wink:).
So
Potential difference across the inductor is -L di/dt.
and (I'm not really sure of this-)
##Q_A(t)## should be ##Q_0## - ##i## t
##Q_B(t)## should be ##Q_0## + ##i## t
Is that right?
Ayesha02 said:
So
Is that right?
A few things. ##Q_A(t) = Q_0 - it## would be correct if the current were constant, however we have no grounds to assume it here. Your second equation also assumes constant current, but ##Q_B(0) = 0## in the problem statement so even if the current were constant there should be no ##Q_0##.
You're right about the PD across the inductor; that is the change in potential in the direction of the current.
Think about it like this; if sphere ##A## has a charge of ##Q_A(t)## and a radius of ##r##, what is its potential? Likewise, what is the potential of sphere ##B##? What is the potential difference from sphere A to sphere B?
Okay so if sphere ##A## has a charge of ##Q_A(t)## and a radius of ##r##, its potential should be k##Q_A(t)## /r ; likewise for B.
the potential difference between the two then becomes k##Q_A(t)## /r - k##Q_B(t)## /r .
is it okay?
Sure, so that gives you (being careful with the signs)
$$\frac{kQ_A(t)}{r} - \frac{kQ_B(t)}{r} = L\frac{di}{dt}$$ There are a few different things you could do; I would suggest eliminating either ##Q_A## or ##Q_B##, and rewriting ##\frac{di}{dt} = \frac{d}{dt}(i)## in terms of either ##Q_A## or ##Q_B## (depending on which one you have left).
What an awful problem!
It's too tempting to neglect the mutual capacitance between A and B and consider only the self capacitance. However (https://en.wikipedia.org/wiki/Capacitance) points out the mutual capacitance equals the self capacitance. We end up with to capacitors "connected to infinity" and another between points A and B.
There can only be mutual inductance when there are conceptually two (or more) inductors (discrete and/or tapped).
Ohh you true!
So
I'm not sure I'm quite getting how to eliminate one of ##Q_A## or ##Q_B## there buddy:|
Ayesha02 said:
So
A current is defined as change in charge. ;)
Fine so i=d ##Q_A##/dt or d##Q_B##/dt. yet, how to eliminate?
Well, what do you think of the sign of the left hand side of your equation?
Moreover, where do you think the charge lost by A will go? If the initial charge of A is ##Q_0##, how can you relate it to that of B as time varies forward?
If I am drinking from a bottle of water of initial volume ##V_0##, and the volume that I drank as a function of time is ##V(t)##, then what is the bottle's volume as time goes on?
So the charge lost by A goes to B.
which means considering ##Q_0## as the initial charge given to A, ##Q_B## should eventually become ##Q_0## - ##Q_A##
so far so good?
Though i didnt quite get you on this..
so far so good?
Perfect. Gj.
The sign of the left hand side of your equation is equal to the sign of its right hand side, so you should choose the change in the current accordingly.
Before A's charge becoming lower than the half of its initial charge, the sign of the difference is positive. This tells you that the derivative of the current is positive, thus the current should be growing. Feel free to add a minus aign if necessary depending on which charge you have chosen to eliminate.
archaic said:
Perfect. Gj.
Alright so what i can gather so far:
1. k ##Q_A##/r - k ##Q_B##/r =L di/dt
2. i= (##Q_0## - ##Q_A##) /t
3. i= (##Q_B##) /t
I still don't see how are we solving this:|
You have found that
and have chosen ##Q_B(t)=Q_0-Q_A(t)##, which give you
$$\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r} = L\frac{di}{dt}$$
You know that ##Q_A(t)-(Q_0-Q_A(t))=2Q_A(t)-Q_0\geq0##, thus for for ##Q_A(t)\geq\frac{Q_0}{2}=\frac{Q_A(0)}{2}##, we have ##\boxed{Li'(t)\geq0\implies i(t)=\frac{dQ}{dt}\text{ is growing.}}##
Since you have chosen to eliminate ##Q_B(t)##, you need to express ##i(t)## using the expression you have found for ##Q_B(t)##, and it needs to satisfy the condition above, and then solve the differential equation.
archaic said:
You have found that
You know that ##Q_A(t)-(Q_0-Q_A(t))=2Q_A(t)-Q_0\geq0##, thus for for ##Q_A(t)\geq\frac{Q_0}{2}=\frac{Q_A(0)}{2}##, we have ##Li'(t)\geq0##.
nope
I'm getting so confused rn.
Ayesha02 said:
nope
Hm, can you please tell me where things are unclear?
See
various thoughts crossing my mind-
1. I have four unknowns ( ##Q_0## ,##Q_A## ,##Q_B## and i ) and only 3 equations
2. Even if manage to solve the equations and find ##Q_A##(t)/ whatever, how will i get the time in which charge flow occurs
could you give me a birds eye view of the sum once again and then let's proceed with equation solving:)
Ayesha02 said:
See
At this point, ignore ##Q_0##. I think that, up until now, we are clear on$$\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r} = L\frac{di}{dt}$$
We need to find the appropriate expression for ##i(t)##; either ##Q'_B(t)##, or ##Q'_A(t)##.
Before losing half of its initial charge, it should be clear that ##Q_A(t)\geq Q_B(t)##, since ##Q_B(t)## starts from being zero coulombs and grows by taking the charge lost from A's.
Thus
$$\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r}\geq0$$
as long as the charge in A is greater than half of its initial value.
Now, we have$$\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r} = L\frac{di}{dt}$$
or, in other terms, ##\alpha=\beta##. If ##\alpha>0##, then what can you infer about ##\beta##?
If ββ is the derivative of some function, then what does its sign tell you about that function?
archaic said:
If ##\beta## is the derivative of some function, then what does its sign tell you about that function?
Oh so I know that ##i## is an increasing function isn't it?
what next then?
Ok, we know that ##i(t)## is growing, and since ##i(t)=Q'(t)##, then ##Q'(t)## should also be growing, or, in mathematics, ##Q''(t)\geq0##.
I haven't foreseen this. We definitely know that ##Q'_A\leq0## and that ##Q'_B\geq0##, but I don't see how we can say anything about their second derivatives without knowing the actual functions.
Since it seems that we have no idea, I suggest we choose ##Q=cQ_B(t)=c(Q_0-Q_A(t))##, where ##c## is either ##1## or ##-1##, and is to be determined later.
This should work as ##cQ''_B=-cQ''_A=ci'(t)## (substitute with the expression you have found for ##Q_B## to check).
Ayesha02 said:
Ohh you true!
Actually, for a given coil of N turns, each turn has mutual inductance with every other turn, which is why coil inductance basically goes as the square of the number of turns. So you weren't completely off base after all! :smile:
