Induction to prove then number of subsets with elements of 3
The discussion revolves around proving that a set with n elements has \(\frac{n(n-1)(n-2)}{6}\) subsets containing exactly three elements, applicable for integers n greater than or equal to 3. The original poster mentions that the professor requires the use of induction for this proof.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to establish the base case for induction by calculating P(3) and exploring the transition from P(n) to P(n+1). They question the addition of subsets containing two elements to the existing formula for three-element subsets.
  • Some participants suggest considering the subsets of the expanded set when a new element is added, prompting questions about how many subsets include or exclude this new element.
  • There is a repeated inquiry about the relevance of the counts of subsets when transitioning from set A to set B, particularly regarding the subsets that include the new element.
  • Participants express confusion about the implications of their findings and the definitions of variables representing the counts of subsets.
The discussion is ongoing, with participants exploring various interpretations of the inductive step. Some guidance has been offered regarding the need to consider subsets that include and exclude the new element, but there is no explicit consensus on the approach or resolution of the problem.
Participants note the requirement for structural induction and express uncertainty about how to apply it effectively. There is also mention of confusion regarding the definitions and relationships between the counts of subsets in the sets A and B.
sta|ker
Prove that a set with n elements has \frac{n(n-1)(n-2)}{6} subsets containing exactly three elements whenever n is an integer greater than or equal to 3.
Our professor wants us to use Induction.
P(n) = \frac{n(n-1)(n-2)}{6}
n \geq 3
Since our professor wants to use Induction, I tried to prove the basis:
P(3)=\frac{3(2)(1)}{6} = \frac{6}{6} = 1
This is true given any set (with elements equal to 3):
\{x_{1}, x_{2}, x_{3}\} has subsets \{\{∅\},\{x_{1}\}, \{x_{2}\}, \{x_{3}\}, \{x_{1},x_{2}\}, \{x_{1},x_{3}\}, \{x_{2},x_{3}\},\{x_{1},x_{2},x_{3}\}\}
So, from here I naturally tried to prove P(n+1). In this process, I'd try to find something to add to P(n) to equal P(n+1). With some guess work, I came up with the following:
\frac{n(n-1)(n-2)}{6} + \frac{n(n-1)}{2} = \frac{n(n+1)(n-1)}{6}.
I noticed (from an example in the textbook) that \frac{n(n-1)}{2} is actually the formula that equates to the number of subsets that contain 2 elements. I'm assuming that this isn't a coincidence. The problem I have from here is: why can \frac{n(n-1)}{2} be added to \frac{n(n-1)(n-2)}{6}? Is there a rule or law I'm missing?
Suppose you have a list of the subsets of 3 elements of some set A. Now you add a new element to A. How many subsets of 3 are t here in the expanded set that do not include the new element? How many are there that do include the new element?
EDIT 2: Ok, just re-read again. So there are 3 sets of 3 in the extended set (lets call this B) that contain the new element, and 1 that doesn't. I'm still not sure of the relevance. I actually just re-read my assignment and our professor wants us to use Structural Induction, which is extremely confusing here.
[STRIKE]EDIT: I misread that (there's 1 subset of 3 in the first, and 3 subsets of 3 in the second). I still don't understand what's being implied though.[/STRIKE]
[STRIKE]Hmm, well, that would be 7 in set A, and if we make set B the set with the 4th element, that would be 7 without the 4th element, and 7 without the first 3. I still don't think I understand how that relates to this.[/STRIKE]
To do the inductive step you need to work more generally. Suppose there are n 3-sets in A. We add one element x to form B. How many 3-sets are there in B which do not use x? How many do use x? When you have answered those the relevance will be quite clear.
So:
n subsets of 4 in A
B = A \cup \{x_{4}\}
A = \{x_{1}, x_{2}, x_{3}\}
B = \{x_{1}, x_{2}, x_{3}, x_{4}\}
So, n=1 for A, and n=4 (1 without x_{4}, 3 with x_{4}).
The only pattern I see here is that there are 3 elements in A and 3 subsets with x_{4} in B. Though I don't think that's a correct correlation...
sta|ker said:
So:
n subsets of 4 in A
No, you must do it with an arbitrary set A, not just a set of three elements. Don't try to ask what A looks like, just accept that it has n subsets of size 3. If you add an element but don't use it, how many subsets of size 3 can you make? The answer is extremely simple!
Alright, so we declare A as a set with n subsets of size 3. If we add one more element, and set it to B, we can say B is a set with n + m subsets of size 3. So, if we say the total size of A's subsets of size 3 is a = n, then we can say the total size of B's subsets of size 3 is b = a + m. I guess we can say m = a - b or m = n - b, but I still don't know what b is or m is.
I'm sorry, I don't mean to be a pain, but I'm just not seeing it.
If you don't use the element that you added to A, how will it change the count of subsets?
It won't change them, that's why I said b would be a+m. a is n and m is the number of subsets that do contain the new element. If you don't use the added element, it isn't going to change the amount of subsets with 3 elements. Regardless, it gave me an idea:
Let a represent the amount of subsets with 3 elements in the set A.
Let b represent the amount of subsets with 3 elements in the set B.
We know that A \subset B, so we can declare: b = a + c where c is the count of all subsets with 3 elements in B that do contain the added element.
We also know that a can be represent by \frac{n(n-1)(n-2)}{6} and b can be represented by \frac{n(n-1)(n+1)}{6}.
So, if we rework b = a + c, we get c = b - a. Substituting our formulas, we get:
c = \frac{n(n-1)(n+1)}{6} - \frac{n(n-1)(n-2)}{6}. This ultimately ends up becoming c = \frac{n(n-1)}{2}. If we add that to P(n) to attempt to obtain P(n+1), it will result in an equal equation.
This is all given that P(n) = \frac{n(n-1)(n-2)}{6} for n \geq 3, and that the base P(3) = 1, which is true, which implies P(n+1).
Would this be considered a valid proof?
Ok, but you did not make it clear that this is what you meant by a and m.
... and b can be represented by \frac{n(n-1)(n+1)}{6}.
No! That is what you are trying to prove, so you cannot assume it.
Think now about about how you would make a 3-subset of B that does use the added element. You have the added element in the 3-set... what else do you need in it?
Hmm, I'm not sure I'm understanding this correctly:
a represents the number of subsets containing 3 elements in a set A.
b represents the number of subsets containing 3 elements in a set B.
B is basically A with an added element, so B = A \cup \{x\}
This means A \subset B, so there is a number we'll call c that represents the subsets of 3 containing the added element.
This means b = a + c.
Now, given all this, are you asking what c (the representative of the number of subsets with 3 elements in B that contain the new element) is?
The only thing I can come up with is that c=b-a.
I don't think I can put it more clearly than I did in the last sentence of my previous post, short of giving you the answer.
Imagine you are constructing a set of 3 elements from B. You are required to use the added element that was not in A. What else do you need to complete the 3-set you are constructing? How many ways are there of doing that?
Alright, I think I have it:
We can obtain c by taking all the subsets with 2 elements in A and adding the extra element from B. So essentially c is the number of subsets with 2 elements in A.
From a previous problem, we know the number of subsets containing 2 elements in a set is calculated using \frac{n(n-1)}{2}. So, by assigning that to c, assigning \frac{n(n-1)(n-2)}{6} to a and \frac{n(n-1)(n+1)}{6} to b, we can plug these equations into b = a + c, getting:
\frac{n(n-1)(n+1)}{6} = \frac{n(n-1)(n-2)}{6} + \frac{n(n-1)}{2}, which is true.
This accurate? Or did I miss it again?
That's it.
haruspex said:
That's it.
Excellent, thank you very much for your patience! :smile:
  • · Replies 21 ·
