What is the difference between induction and polarization?
Induction and polarization are related but distinct concepts in electrostatics. Induction refers to the process where a neutral object becomes charged due to the influence of an external electric field, while polarization is the separation of charges within a material, resulting in a temporary charge distribution. For example, bringing a positive charge near an insulating material causes electrons to move closer, inducing polarization. The discussion highlights that induction is an action that leads to polarization as a result. Understanding these differences is crucial for applications in various devices, such as copiers.
IKonquer
I've heard both words used a lot and am having difficulty understanding the two. Is there a difference between them?
Thanks in advance
Thanks in advance
Well you induce polarization to occur. If for example, you take an insulating material, and you bring a positive charge close, the electrons will "gather" closer to the positive charge. So you have induced momentary polarization (separation of charge). The same can be done with a conducting material and can actually be used to separate charge on a more permanent basis. The type of material you are inducing polarization to occur in can produce some interesting desired effects that are used in a number of different types of devices. Copiers, on and on...
I think I am seeing how you can separate the charges through polarization. But let's say you rub electrons from your hair with a comb. Why does the comb become negatively charged? I don't think I understand this idea of transfer of charge.
So is induction when a neutral object becomes charged and polarization just the separation of charge? Also I don't see how a comb can just pick up negative charge in my previous post.
IKonquer said:
So is induction when a neutral object becomes charged...
Please READ the wiki link I posted :)
this is not what is written there !
You can add any charge (+/-, size) to objects that have any other charge (+/-, size) no law against it (practically). but also you can affect the distribution of charge inside an object by electromagnetic fields (without taking or giving any new charge) !
Induction - action taken; Polarization = results.
Right?
  • · Replies 25 ·
