Inelastic collision kinetic energy lost?
3 replies · 4K views · last reply
girl52
inelastic collision...kinetic energy lost?
a bullet with a mass of 6 g is fired through a 1.25kg block of wood on a frictionless surface. initial speed of the bullet is 896 m/s and speed of bullet after it passes through it is 435 m/s. what's the final velocity? how much KE is lost?
ke lost=ke initial-ke final
ke lost=1/2mvf-1/2mvi
i got 11.2 m/s for the final velocity of the wood
KEi=1/2(.006)(896^2) + 0
KEf=1/2(.006)(435^2) + 1/2(1.25)(11.225^2)
i got 2408.228 - 488.925
thats not negative..where did i go wrong??
Don't forget to square the velocity when calculating KE. But first try using conservation of momentum, and show your work, please.
how did you arrive at this number?
The change in energy (final minus initial) is negative...if you use (initial minus final), you get your signs reversed. Don't do it that way, the minus signs are bad enough without compounding them.
