Does kinetic energy loss equal momentum change in inelastic collision?
11 replies · 3K views
xxphysics
In an inelastic collision is the change in kinetic energy equal to the difference of final and initial momentum if one of the objects is initially at rest? For example:
m1v = (m1+m2)Vf -----> 0 = (m1+m2)Vf - m1v1
1/2(m1+m2)Vf^2 - 1/2m1v^2 = (m1+m2)Vf - m1v1
Or totally wrong? Thanks!
Momentum is conserved, so the difference between the initial and final momentum has to be zero. You've captured that when you wrote ##(m_1+m_2)v_f-m_1v_1=0## for the particular case in which ##m_2## starts at rest and the two masses stick together in the inelastic collision.
So when you ask whether the change in kinetic energy is equal to the difference between the initial and final momentum, you're asking whether the change in kinetic energy is equal to zero.
This would be a good time to stop and think about the definition of "inelastic collision".
OK, my take on this is that, this is a rather odd question. You're asking if
ΔK = Kf - Ki
This is odd because that is the DEFINITION of ΔK!
Zz.
This is not what the quoted sentence says. :)
I am aware that the OP is mixing momentum with kinetic energy. I was hoping that this was an oversight, and not out of ignorance.
Zz.
It's more than possible that he didn't actually know??
ΔK = Kf - Ki
Zz.
Zz
Zz.
Zz
Chestermiller said:
Totally wrong. The units don't even match.
Thank you :) I just thought they were both looking at the change in velocity and in both equations there is a way to account for the differences in mass (before and after collision) so I didn't think was absurd to wonder if there is a connection between the formulas.
ΔK = Kf - Ki
Zz.
No my question was if you could relate the momentum equation of an inelastic collision to the change in kinetic energy of that collision
I see what you are after. There isn't a 1:1 relationship between the two quantities. Particular circumstances will give particular relationships.
Two situations with the same total momentum and different KE transferred to the collision. For convenience I have chosen to bring the motion to a halt. :
Two equal masses m&m, traveling towards each other at v and -v (Earth frame of reference) will have a total momentum of zero and a total KE of mv2. Now reduce one of the masses to 0.1m and increase its velocity to 10v. Total momentum is still zero but the KE is (mv2 +0.1m(100v2))/2 = (1+10)mv2/2 =5.5mv2.
This two trivial cases are enough to show that your idea can't be relied on. It's the squaring of the velocity that upsets things.
