Inequalities in the real numbers
The discussion revolves around proving inequalities related to Dedekind Cuts, specifically demonstrating that if \( p \in \alpha \) and \( \epsilon > 0 \) satisfies \( 0 < \epsilon < 1 \) and \( \epsilon < \frac{2 - p^2}{2p + 1} \), then \( (p + \epsilon)^2 < 2 \). The participants clarify the steps needed to derive this conclusion, emphasizing the algebraic manipulation of inequalities. The final proof confirms that \( (p + \epsilon) \in \alpha \), thereby validating the properties of Dedekind Cuts.
  • Understanding of Dedekind Cuts in real analysis
  • Familiarity with inequalities and algebraic manipulation
  • Knowledge of the properties of real numbers
  • Basic proficiency in mathematical notation and logic
  • Study the properties of Dedekind Cuts in detail
  • Learn about algebraic proofs involving inequalities
  • Explore the implications of the completeness property of real numbers
  • Investigate other methods of defining real numbers, such as Cauchy sequences
Mathematicians, students of real analysis, and anyone interested in the foundational aspects of real numbers and their properties.
mcastillo356
TL;DR
It's so a basic question that I feel shame.
I'm still not sure about this solved reasoning that involves inequalities
How do we get ##\epsilon(2p+\epsilon)<\epsilon(2p+1)<2-p^2## from ##0<\epsilon<1## and ##\epsilon<\dfrac{2-p^2}{2p+1}##?
Answer: As we have ##\epsilon<1##, we've got ##2p+\epsilon<2p+1##; therefore, ## \epsilon(2p+\epsilon)<\epsilon(2p+1) ##;
-as we have ##\epsilon<\dfrac{2-p^2}{2p+1}##, we also have ##\epsilon(2p+1)<2-p^2##. Is the red-coloured argue what I don't understand
Greetings, appreciated PF
If ##\varepsilon < 1## then ##x+\varepsilon < x+1##. Set ##x=2p##. Then ##2p+\varepsilon <2p+1.## Now if ##a<b## then ##a\cdot \varepsilon < b\cdot \varepsilon ## because ##\varepsilon >0##. Now set ##a=2p+\varepsilon ## and ##b=2p+1## to get ##(2p+\varepsilon )\cdot \varepsilon < (2p+1)\cdot \varepsilon ##.
Fantastic, I never imagined it could be explained in so an easy way.
Thanks, fresh_42!
Hi, PF, there is something more about this thread: I want to contextualize the question, and, by the way, ask another two questions. I beg you a pardon if this means to change the thread's place.
It's about Dedekind Cuts, concretely ## \sqrt 2 = \{r\in \mathbb Q\mid r<0\}\cup \{r\in \mathbb Q\mid r\geq 0,\ r^2<2\} ##
And the task is to prove ##\alpha=\sqrt 2## is a cut, without mentioning ##\sqrt 2##
1- As ##1^2<2<2^2##, it satisfies ##1\in\alpha## and ##2\in \mathbb Q\setminus\alpha##; so the first property of Dedekind Cuts is satisfied (for example, the proof that ##\alpha\neq \mathbb Q## is this: ##2\notin \alpha##, because it doesn't satisfy neither ##2<0## nor ## 2\geq 0 ## and ##2^2<2##).
2-If ##p\in\alpha## and ##q<p##, or ##q<0##, in which case ##p\in \alpha##, by definition, or ##0\leq q<p##; hence ##p^2<q^2<2##. Therefore, ##q\in \alpha##.
Why is that ##p^2<q^2<2##?
3- If ##p\in\alpha##, alternatively ##p\leq 0##, in which case ##p<1\in\alpha##, or ##p>0##, in which case ##p^2<2##. Let's see what must require a rational number ##\epsilon>0## so that ##p+\epsilon\in \alpha##:
##(p+\epsilon)^2=p^2+2p\epsilon+\epsilon^2<2##
This is equivalent to ##\epsilon(2p+\epsilon)<2-p^2##. If we take ##0<\epsilon<1## and ##\epsilon<\dfrac{2-p^2}{2p+1}## then
##2(p+\epsilon)<\epsilon(2p+1)<2-p^2##, so ##p<q=p+\epsilon\in \alpha##
Why this implication?
Greetings! Hope not to have treated too badly the english.
I don't understand the bit in red at the end. You have:
Now you have to show that, with these bounds on ##\epsilon## we have ##(p + \epsilon)^2 < 2##. I.e. ##p + \epsilon \in \alpha##.
Hello, PeroK
The target consists in suppose ##p\in \alpha##, this is, we have ##p## that satisfies ##p<0## or ##p\geq 0## and ##p``^2<2## (not mentioning ##\sqrt 2##), and I must find a ##q>p## that satisfies the same (whithout references to ##\sqrt 2##.
All I find in the proof is a dance of ##\epsilon##, ##p##, 0, 1, and 2.
Let's see, I think I understand:
##2(p+\epsilon)<(p+\epsilon)^2<2##: ##2(p+\epsilon)=q\in \alpha##
mcastillo356 said:
Hello, PeroK
I don't understand that at all.
You have to show that:
##0<\epsilon<1## and ##\epsilon<\dfrac{2-p^2}{2p+1} \ \ \Rightarrow \ \ (p + \epsilon)^2 < 2##
That should be quite simple.
PS you could check it out for ##p = \frac 7 5##.
It works, but, how can I prove it algebraically?
Using algebra! Starting with ##(p + \epsilon)^2 = p^2 + 2p\epsilon + \epsilon^2##
Ok, processing...
@mcastillo356, I revised your thread title slightly, changing "inequations" to "inequalities," which is what we call them in English. Inconsistent, but that's English for you.
I know only to prove this:
Dedekind Cuts, third property:
III If ##p\in\alpha## then ##p<r## for some ##r\in \alpha##
For example, the cut ##\sqrt 2 = \{r\in \mathbb Q\mid r\leq 0\}\cup \{r\in \mathbb Q\mid r> 0,\ r^2<2\}##. If ##p\in\alpha##, alternatively ##p\leq 0##, in which case ##p<1\in\alpha##, or ##p>0##, in which case ##p^2<2##. Let's see what must require a rational number ##\epsilon>0## so that ##p+\epsilon\in \alpha##:
This is equivalent to ##\epsilon(2p+\epsilon)<2-p^2##. If we take ##0<\epsilon<1## and ##\epsilon<\dfrac{2-p^2}{2p+1}## then we've found the proper ##\epsilon##.
Problem solved?
##2(p+\epsilon)<\epsilon(2p+1)<2-p^2## would be another way to express the two inequalities that bound ##\epsilon##
Problem solved?
I would still like to see a direct calculation that starts with that ##\epsilon## and shows that ##(p+\epsilon)^2 < 2##.
I will try. I'll answer tomorrow
Hello, PeroK, PF
##0<\epsilon<1## and ##\epsilon<\dfrac{2-p^2}{2p+1}\Rightarrow{(p+\epsilon)^2<2}##
##0<\epsilon<\dfrac{2-p^2}{2p+1}##
##\Rightarrow{0<\epsilon(2p+1)<2-p^2}##
##\Rightarrow{p^2<2}##
##\therefore{(p+\epsilon)^2<2}##
:confused:
mcastillo356 said:
Hello, PeroK, PF
:confused:
We already knew that ##p^2 < 2##. It was ##(p+ \epsilon)^2 < 2## that must be shown.
I gave you the first step previously (which you ignored!): $$(p+\epsilon)^2 = p^2 + 2p\epsilon + \epsilon^2 = p^2 + \epsilon(2p + \epsilon)$$ The second step is: $$p^2 + \epsilon(2p + \epsilon) < p^2 + \epsilon(2p + 1) \ \ (\text{as} \ \ \epsilon <1)$$ Just two steps left for you now!
Hi, PeroK, PF
$$(p+\epsilon)^2=p^2+2p\epsilon+\epsilon^2=p^2+\epsilon(2p+\epsilon)$$
$$\epsilon<1\Rightarrow p^2+\epsilon(2p+\epsilon)<p^2+\epsilon(2p+1)$$
$$\epsilon<\dfrac{2-p^2}{2p+1}\Rightarrow \epsilon(2p+1)<2-p^2$$
$$p^2+\epsilon(2p+\epsilon)<p^2+\epsilon(2p+1)<2-p^2+p^2$$
$$\Rightarrow (p+\epsilon)^2<2\Rightarrow (p+\epsilon)\in \alpha$$
? :confused:
:partytime:
  • Love
