Inertia units for a synchronous machine
4 replies · 2K views · last reply
gab_xd
TL;DR
Are [kg m^2] and [kg m^2 /rad^2] equivalent?
Hello everyone,
I'm sorry if this is not the right sub-forum to post this, but this doubt has been haunting me for a while.
I've got some rotatory machine -let's say, generic synchronous machine-. Turns out there are typical values for [kg m^2] (inertia) in the 2-10 range; the software I'm using asks for inertia values considering [kg m^2 / rad^2] units. Are these equivalent? A quick Google search tells me that they are, but I'm still confused as to why would you blatantly put [rad^2] in there without consequences.
Thanks in advance!
Anybody's guess. My guess is narrowmindedness :wink: .
For ##\tau = I\alpha## that would lead to kg m2/rad and for ##E={1\over 2} I\alpha^2 ## you'd get your kg m2/rad2.
You could try to find an example in your software documentation to check that kg m2 is adequate.
(And if you find a counter-example, please post here !)Disclaimer: not an expert, just a physicist -- and the thread remained unanswered for three days, which is atypical for PF :smile:
Hi BvU,
Thanks for your answer! I thought the question remained unanswered because "it was too basic" :(
During the weekend, I tried getting the units out myself but didn't get to anything conclusive; I will try to find some examples in the software documentation, and will let you know as soon as I can.
I just hope the person that listed the units as ##kg m2## didn't use RPM as his angular frequency unit. :p
Part of the problem is that angles are a ratio, and thus have no dimension of their own. That's controversial. The link below is a PF Insights article on that subject. The comment thread on the article is 105 posts long.
https://www.physicsforums.com/insights/can-angles-assigned-dimension/
If an angle has no dimensions, "[kg m^2] and [kg m^2 /rad^2] equivalent" is true.
Thanks Anorlunda!
Now that I think about it, it's not the first time I have had problems with angle's dimensions. I'll read that post as soon as I can; took a quick look and it surely looks like a rabbit hole.
