Inertia units for a synchronous machine
The discussion revolves around the units of inertia for a synchronous machine, specifically the confusion between using [kg m²] and [kg m² / rad²]. Participants explore the implications of these units and the dimensionality of angles in the context of rotational dynamics.
  • One participant questions the necessity of including [rad²] in the inertia units, expressing confusion over its implications.
  • Another participant suggests that the inclusion of [rad²] might stem from a narrow-minded approach, providing equations to illustrate how inertia relates to torque and energy.
  • A participant notes the dimensional nature of angles, stating that if angles are dimensionless, then [kg m²] and [kg m² / rad²] could be considered equivalent.
  • There is a suggestion to check the software documentation for examples to clarify the appropriate units for inertia.
  • One participant expresses concern about the potential misuse of RPM as a unit of angular frequency in the context of inertia calculations.
Participants express uncertainty regarding the dimensionality of angles and the equivalence of the inertia units. There is no consensus on the implications of using [rad²] in the context of inertia.
Some participants highlight the controversial nature of angles being dimensionless, referencing a lengthy discussion on the topic in a related article.
gab_xd
TL;DR
Are [kg m^2] and [kg m^2 /rad^2] equivalent?
Hello everyone,
I'm sorry if this is not the right sub-forum to post this, but this doubt has been haunting me for a while.
I've got some rotatory machine -let's say, generic synchronous machine-. Turns out there are typical values for [kg m^2] (inertia) in the 2-10 range; the software I'm using asks for inertia values considering [kg m^2 / rad^2] units. Are these equivalent? A quick Google search tells me that they are, but I'm still confused as to why would you blatantly put [rad^2] in there without consequences.
Thanks in advance!
Anybody's guess. My guess is narrowmindedness :wink: .
For ##\tau = I\alpha## that would lead to kg m2/rad and for ##E={1\over 2} I\alpha^2 ## you'd get your kg m2/rad2.
You could try to find an example in your software documentation to check that kg m2 is adequate.
(And if you find a counter-example, please post here !)Disclaimer: not an expert, just a physicist -- and the thread remained unanswered for three days, which is atypical for PF :smile:
Hi BvU,
Thanks for your answer! I thought the question remained unanswered because "it was too basic" :(
During the weekend, I tried getting the units out myself but didn't get to anything conclusive; I will try to find some examples in the software documentation, and will let you know as soon as I can.
I just hope the person that listed the units as ##kg m2## didn't use RPM as his angular frequency unit. :p
Part of the problem is that angles are a ratio, and thus have no dimension of their own. That's controversial. The link below is a PF Insights article on that subject. The comment thread on the article is 105 posts long.
https://www.physicsforums.com/insights/can-angles-assigned-dimension/
If an angle has no dimensions, "[kg m^2] and [kg m^2 /rad^2] equivalent" is true.
Thanks Anorlunda!
Now that I think about it, it's not the first time I have had problems with angle's dimensions. I'll read that post as soon as I can; took a quick look and it surely looks like a rabbit hole.
10K
  • · Replies 42 ·
15K
28K
