jeremyfiennes
- 323
- 17
- TL;DR
- Under what circumstances are they different?
jeremyfiennes said:Hatch, R.R. (2007) "A New Theory of Gravity", Physics Essays 20:1
jeremyfiennes said:"Inertial and gravitational mass diverge in value as a function of velocity." So he is wrong?
PeterDonis said:Also, since in relativity "velocity" has no invariant meaning, it's hard to see what "as a function of velocity" would mean physically.
metastable said:the time dilation experienced by a particle has dependence on the length of its world line compared to the length of another particle’s world line, when the particles are separated and then brought back together
metastable said:Isn’t the “age” of the particle a function of its velocity?
Although it can be expressed as a functional of the velocity, it is an invariant quantity. However, you have misunderstood what it means to have a short world-line. The length of your world-line is the amount that you have aged. Hence, the shorter the world-line, the younger the object. Now, geometry in spacetime does not work the same way as geometry works in a "normal" space so the object moving around actually has a shorter world-line.metastable said:If 2 particles are at rest, one then moves around wildly and is then brought back to rest with respect to the other particle, isn’t it now younger than the other particle that had a shorter world line or in plain language younger than the particle that had “less velocity?” Isn’t the “age” of the particle a function of its velocity?
If, by "at rest", you actually mean "at rest in an inertial frame" then yes. Otherwise, maybe. It depends on what you mean by "at rest".metastable said:If 2 particles are at rest, one then moves around wildly and is then brought back to rest with respect to the other particle, isn’t it now younger than the other particle
The length (more precisely, the interval) of the worldline is the key thing here, the invariant on which everyone will agree. Whether or not an object had "more" or "less" velocity is dependent on your choice of frame.metastable said:isn’t it now younger than the other particle that had a shorter world line or in plain language younger than the particle that had “less velocity?”
If you pick a frame then you can express the length of the worldline as a function solely of the velocity of the particle with respect to the frame. The form of the expression depends on your choice of frame, however, which is how the result can be the same even if you choose to use a frame where the velocity of the "wildly moving" one is zero.metastable said:Isn’t the “age” of the particle a function of its velocity?
If I understand this correctly,"not accelerating" an unstable particle can "hasten" its loss of inertial mass.stevendaryl said:How much your t-coordinate changes depends on the t-component of your velocity
metastable said:If I understand this correctly,"not accelerating" an unstable particle can "hasten" its loss of inertial mass.
Should that say "3-velocity"? 4-velocity is normalised to ##c##. Or am I missing your point?stevendaryl said:larger 4-velocity.
Ibix said:Should that say "3-velocity"? 4-velocity is normalised to ##c##. Or am I missing your point?
Nugatory said:Although you’ll also have to start later and closer.
