Convergence or Divergence of Infinite Series: Methods and Examples
The discussion focuses on determining the convergence or divergence of the series Ʃ(1/(n*ln(n)^2 - n)) from n = 1 to infinity. Participants initially struggle with the comparison test due to the series being negative for the first two terms. It is clarified that the convergence or divergence is determined by the tail of the series, not the initial terms. The Limit Comparison Test requires positive sequences, but it is noted that analyzing the series from n = 3 is sufficient. Ultimately, the integral test is successfully applied from n = 3 to infinity, confirming that the series converges.
physicsernaw
Determine convergence or divergence using any method covered so far*:
Ʃ(1/(n*ln(n)^2 - n)) from n = 1 to infinity*The methods are the following:
- Dichotomy for positive series (if the partial sums are bounded above and the series is positive, the series converges)
- Integral Test
- Convergence of p-Series
- Comparison test
- Limit Comparison Test
n/a
The series is negative for n = 1 and 2, so I am left with Comparison test but I am having trouble determining what sequence to compare to. I am not "seeing" it.
Is that denominator ##n\ln^2(n) -n## or ##n\ln (n^2)-n##?
- Integral Test
- Comparison test
n/a
It doesn't matter if the first few terms of the series are negative. It is the tail end of the series that determines convergence or divergence. So don't rule out the other methods.
The denominator is the first one you posted, n*(ln(n))^2 - n.
In my book for the Limit Comparison Test it states "Let a[n] and b[n] be positive sequences." I assumed that "positive sequences" meant positive for all n [1, infinity). So it is really saying that if the sequence converges to a positive value or diverges "positively" than one can use the Limit Comp test on these sequences? Or am I still off base
If ##\sum_{n=3}^\infty a_n## converges or diverges, adding ##a_1+a_2## to it won't change the convergence or divergence. So analyze the sum from 3. I would suggest a combination of comparison and integral tests.
Likes 1 person
Ahh I see thanks for clarifying. I will reattempt the problem.
EDIT: Got it by simply using integral test from n=3 to infinity. The integral converges so the series must as well. Thanks LCKurtz.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
