Infinite Square Well (Conceptual)
After a position measurement in an infinite square well, the wave function collapses to a specific position state, |x'⟩. At a later time t>0, the wave function evolves according to the time evolution operator, which can be expressed in terms of the eigenstates of the infinite square well. The discussion highlights that while the wave function may become a superposition of stationary states, the expectation value of the Hamiltonian does not remain constant before and after the measurement. This indicates that the energy expectation value can change post-measurement, contradicting the assumption of energy conservation. The key takeaway is the importance of correctly applying the time evolution operator to understand the wave function's behavior after measurement.
Nicolaus
Say, for example, a wave function is defined as 1/sqrt(2)[ψ(1)+ψ(2)] where ψ are the normalized stationary state energy eigenfunctions of the ISQ.
Now, say I make a measurement of position. What becomes of the wavefunction at a time t>0 after the position measurement (i.e. after it has had time to evolve)?
I would assume that the wave function would become a superposition of inifinitely many stationary states, but such that the expectation value of the Hamiltonian (energy) is the same so as to stay in line with the conservation of energy.
That's why the time evolution operator commutes with Hamiltonian.
Let's say at t=0, you found your particle at ##x=x'## with probability ##|\langle x' | \Psi \rangle|^2##, then right after this point in time, the initial state before measurement collapses to ##|x' \rangle##. If you want to know how it evolves with time, then just apply the time evolution operator. If you want it to be expressed in the known entities such as the eigenstates of the ISW, insert the completeness operator in the space spanned by the ISW eigenstates in between the time evolution operator and ##|x' \rangle##.
Do you mean that the expectation value of energy would be the same before and after the measurement? If so, that's not the case.
Likes blue_leaf77
  • · Replies 19 ·
  • · Replies 18 ·
