Info on soundwaves and overtones
  • Thread starter Thread starter djef
The discussion centers on the concept of soundwaves and overtones, specifically the first harmonic in a tube open at one end. It explains that the first resonant frequency contains only a quarter of a wave, leading to the conclusion that the wavelength is four times the length of the tube. This is due to the wave needing to complete a full cycle, which requires going up, returning, going down, and returning again. The closed end of the tube acts as a node, while the open end serves as an antinode. Understanding this relationship clarifies why the wavelength is four times the tube's length.
djef
hallo all,
while reading some info on soundwaves and overtones I found the following statement on wikipedia:
"The first overtone is the first allowed harmonic above the fundamental frequency (F1).
In the case of a system with two different ends (as in the case of a tube open at one end), the closed end is a node and the open end is an antinode. The first resonant frequency has only a quarter of a wave in the tube. This means that the first harmonic is characterized by a wavelength four times the length of the tube."
now I want to know why it is like this:
Why the 4 ?
how do they get that?
happy new year!
Why the 4 ?
Hallo djef! :wink:
The wave has to go up :rolleyes:, come back, go down :frown:, and come back, to do one wavelength.
For a tube closed at one end, the wave only has time to go up :rolleyes:
that's 1/4 of the wavelength. :smile:
oh yes, indeed, thanks a lot tiny-tim
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 58 ·
