Inhomogeneous Second Order ODE
4 replies · 2K views
0131413
What is the value of a such that the solution of the initial-value problem satisfies limx->infinity y(x) = 0?
y''+y'=e^(-x), y(0)=1, y'(0)=a
Not sure what to do with the missing y term...
yp=Ae^(-x), y'p=-A^(-x), y''p=A^(-x)
Ae^(-x)-A^(-x) = 0 so
yp=Axe^(-x), y'p=-Axe^(-x)+Ae^(-x). y''p=Axe^(-x)-Ae^(-x)-Ae^(-x)
Axe^(-x)-Ae^(-x)-Ae^(-x)-Axe^(-x)+Ae^(-x)=e^(-x)
-Ae^(-x)=e^(-x)
A=-1
The general solution is C1e^(0)+C2e^(-x) (?)
y=te^(-x)+C1e^(0)+C2e^(-x)
y'=-te^(-x)+e^(-x)-C2e^(-x)
y(0)=0+C1-C2=1
y'(0)=0+1-C2=a
C2=1-a
I know this is wrong, multiple numbers can fit into a. Thanks!
-Ae^(-x)=e^(-x)
A=-1
That's the general solution (complementary solution) of the homogeneous equation, yes. No point in the e0 term; it is just 1:
yc = C1 + C2e-x.
But up above you found the particular solution. Since A = -1, what do you get for yp?
There shouldn't be any t in this equation. What is the correct yp?
y(0)=0+C1-C2=1
y'(0)=0+1-C2=a
C2=1-a
Yes, it's wrong but that isn't why. Remember, changing a changes the problem so different a gives the answer to a different equation. Fix your y and express your answer in terms of a. And lose the variable t.
I'm sorry that t is supposed to be an x. I did forget the negative sign when trying to solve the general solution, ouch.
I thought it would be xe^(-x) since using yp=Ae^(-x) I ended up with Ae^(-x)-Ae^(-x).
Now I have
y=-xe^(-x)+C1+C2e^(-x)
y'=xe^(-x)-e^(-x)-C2e^(-x)
y(0)=C1+C2=1
y'(0)=-1-C2=a
C1=1+1+a=0 (Since C1 needs to be 0 for x->infinity to be 0)
So a is -2?
I agree. So what is your final solution to the problem? Once you have it you can plug it into the equation, initial conditions and check the limit and you will know for sure you have no arithmetic mistakes.
C2=-3
The equation that satisfies the problem is y=-xe^(-x)-3e^(-x)
y'=xe^(-x)-e^(-x)+3e^(-x)
y''=-xe^(-x)+e^(-x)+e^(-x)-3e^(-x)
-xe^(-x)+2e^(-x)-3e^(-x)+xe^(-x)-e^(-x)+3e^(-x)=e^(-x)
Final answer to the question of what value of a satisfies the problem:
a=-2
Thanks a lot. :)
