Initial compression of a spring
The discussion centers on the differences between tension springs and compression springs, specifically regarding their initial tension and compression requirements. Tension springs are typically designed for measuring forces over a range, while compression springs serve primarily as energy absorbers. An open wound compression spring can function in both tension and compression without preload. The practical applications of initial compression in springs are confirmed, with examples including automotive springs that are pre-compressed before installation and further compressed by the vehicle's weight and road conditions.
  • Understanding of spring mechanics
  • Knowledge of tension and compression spring applications
  • Familiarity with preload concepts in spring design
  • Basic principles of energy storage in mechanical systems
  • Research the design principles of tension and compression springs
  • Explore the concept of preload in spring applications
  • Learn about the mechanical properties of open wound springs
  • Investigate the role of springs in automotive suspension systems
Mechanical engineers, product designers, and anyone involved in spring design and application in various mechanical systems.
vin300
My question here is a simple one. Most tension springs come with an initial tension requirement for spring action. Is it that tension springs are usually used for measuring through some range while compression springs are usually energy absorbers that such a difference is built into them? Also, would a compression spring with an initial compression requirement serve any practical purpose?
If you start with an open wound spring (such that the coils are not touching), it can be used in either tension or compression without the need for any preload at all. Either can be used as an energy storage mechanism. Initial tension or initial compression is used in many situations, so the answer to your last question is "yes."
The springs on some cars are compressed before fitting and then again by the weight of the car... and only then by the bumps in the road.
Likes Nidum
  • · Replies 58 ·
  • · Replies 70 ·
