Initial velocity of a ram headbutting a castle
The discussion revolves around calculating the initial velocity of a ram headbutting a castle, given specific coordinates and conditions. A catapult at the coordinates can hit the castle if it shoots at maximum range at a 48º angle, while the ram has an 855m head start but is slowed by friction. The problem requires applying physics principles, particularly projectile motion and dynamics, to determine the necessary initial velocity. The user expresses difficulty in solving the problem and seeks guidance on relevant equations and calculations. To find a solution, one must utilize online resources that explain projectile trajectories and friction effects.
kjwx
Problem: Starting co-ordinates S 45° 50.061 E 170° 27.079
A catapult stationed at the above coordinates will hit the castle, if it shoots at maximum range (X meters) at 48ºtrue. Assume equal initial and final elevation for the projectile’s trajectory, and the projectile’s initial velocity is V.
A ram beginning its run with 855m head-start and the same initial velocity V but slowed down by scrub (coefficient of dynamic friction m=5) will also come to a halt exactly at GZ. The ram is not propelled by any external force, and is bound to a horizontal surface.
Relevant equations and solution attempt: Sorry, I just don't know. This isn't a learning institution-related question so I don't have anybody to turn to for help. Am trying to solve as part of a geocaching problem. Tried taking a crash course in physics online but still can't figure out how I proceed.
Solution: To solve this problem, you will need to use the laws of physics and the principles of projectile motion. You can find a lot of good tutorials online that will teach you how to calculate trajectories for projectiles, as well as the equations needed to calculate the distance traveled by an object with a given initial velocity and coefficient of dynamic friction. Once you have the equations you need, you can plug in the known values (starting coordinates, maximum range, initial velocity, etc) to calculate the distance traveled by the projectile and the ram.
