Installing SQL Server Dev Config Manager (Snap in)
  • Thread starter WWGD
    Server Sql
1 reply · 3K views · last reply
Homework Helper
Hi All,
It seems SQL Server's Dev 2017 config manager does not come " built in" within , and it is now a snap in. When I try to install it through Control Panel, I get the error message: Cannot connect to WMI provider. You do not have permission or the server is unreachable.
Screenshot of a Windows Computer Management window showing a Connection failed message with 'Cannot connect t...' in red, under SQL Server Configuration Manager in the Services and Applications tree, over a Paint window.
https://support.microsoft.com/en-us...en-sql-server-configuration-manager-in-sql-se
Suggests as a work around to go to the command line and enter:
mofcomp "%programfiles(x86)%\Microsoft SQL Server\number\Shared\sqlmgmproviderxpsp2up.mof" (**)
Where number is in the list given. BUT no numbers are assigned for versions after 2012. In my Microsoft SQL Server folder I have subfolders numbered 80,90, 110, 120, 140.
Windows File Explorer window in Shared folder showing Microsoft SQL Server version subfolders 80, 90, 110, 120 and 140 in the left navigation pane, with DLL and EXE files listed on the right.
It would seem I should use 140 as a number in (**) above.
Is this correct?
In the page linked above, it says that the problem comes from having a 32-bit instance and another 64-bit instance, but both my instances are 64-bit.
Thanks.
EDIT: While we're at it, if someone knows how to filter within Profiler, I would appreciate any advice on how to do it.
  • Screenshot of a Windows Computer Management window showing a Connection failed message with 'Cannot connect t...' in red, under SQL Server Configuration Manager in the Services and Applications tree, over a Paint window.
  • Windows File Explorer window in Shared folder showing Microsoft SQL Server version subfolders 80, 90, 110, 120 and 140 in the left navigation pane, with DLL and EXE files listed on the right.
Never mind, thanks, I found a folder containing the needed file --it was 140-- and made the change, needed to compile a n .mof. Still, it did not work out, so I will uninstall and reinstall.
