Insulated boundary for circular laplace equation?
7 replies · 3K views · last reply
richyw
Consider the Laplace’s equation, ∆u(r,θ) = 0, inside the quarter-circle of radius 2 (0 ≤ θ < π, 0 ≤ r ≤ 2), where the boundary θ is insulated, and [itex]u(r,\theta/2)=0[/itex]
Show that the insulated boundary condition can mathematically be expressed as
[tex]\frac{\partial u}{\partial \theta}u(r,0)=0[/tex]
It's insulated, so I think that means[tex]]\frac{\partial u(r,0)}{\partial t}=0[/tex]If we use separation of variables [itex]u(r,\theta)=\Phi(\theta)G(r)[/itex] then wouldn't insulated mean I need to take the time derivative of this, using the chain rule?
ok I now know that[tex]\Lambda u(r,\theta)\cdot \hat{n}=0[/tex]where [itex]\hat{n}[/itex] is an outward pointing unit normal vector. how do I determine [itex]\hat{n}[/itex]?
Could you tell us what physical quantity [itex]u[/itex] represents? I assume from the context that [itex]u[/itex] is electric potential with [itex]\mathbf{E} = - \nabla u[/itex].
No. "Insulated" means "the flux of charge across the boundary is zero". That by Gauss's law is equivalent to "[itex]\mathbf{E}[/itex] is parallel to the boundary".
u is temperature here. also that lambda is supposed to be the gradient operator. on a sidenote, what is the latex syntax for that?
anyways in this situation insulated would mean the heat flux across the boundary = 0
so I was initially wrong about the time derivative, but have since corrected it to the formula above. Now I think that in this situation, whatever the normal unit vector to the boundary is, it would be perpendicular to the radial vector.
if [itex]\hat{n}=\hat{\theta}[/itex] then I would get[tex]\frac{\partial u(r,0)}{\partial\theta}=0[/tex], so perhaps this practice exam has a typo? Either way, I am not exactly sure why [itex]\hat{n}[/itex] would be in the [itex]\hat{\theta}[/itex] direction, mostly because I don't know what [itex]\hat{\theta}[/itex] even is!
\nabla
The heat flux is [itex]\kappa \nabla u[/itex], where [itex]\kappa[/itex] is the thermal diffusivity, which does indeed reduce to
[tex] \hat{\mathbf{n}} \cdot \nabla u = 0[/tex]
The boundary is [itex]\theta = 0[/itex], which is parallel to [itex]\hat r[/itex]. The normal to the boundary must therefore be parallel to [itex]\hat \theta[/itex].
To get the del operator use \nabla.
Your expression for insulated boundary doesn't look correct to me. I would think it would be$$
u_r(2,\theta) = 0,~0\le \theta\le \pi$$for the semicircle and$$
u_\theta = 0$$along the x axis.
That is the correct answer, and there is an extra [itex]u[/itex] in the question.
[itex]\hat \theta[/itex] is the unit vector in the direction of increasing [itex]\theta[/itex]. If [itex](x,y) = (r \cos \theta, r \sin \theta)[/itex] then
[tex] \hat r = (\cos \theta, \sin \theta)[/tex]
and
[tex] \hat \theta = (-\sin\theta, \cos\theta)[/tex]
Conveniently, [itex]\hat r \cdot \hat \theta = 0[/itex].
