Integral equation for large surfaces
6 replies · 4K views
Apashanka
We often neglect the terms of a surface integral ##\int_v(\nabla•A)dv=\int_s(A•ds)## for ##s## to be very large or ##v## to be very large,
What is actually the reason behind this to neglect??
The field ##\vec A## is assumed to go to zero at infinity at a rate faster than the rate at which the surface grows.
Okk got it ...thanks @Orodruin
But if the rate at which the vector field ##A## goes to zero at infinity is slower than the rate at which the surface grows ,then also it would be zero ,isn't it??
No. You need the assumption of the field going to zero fast enough. Take the example of the field of a single point charge.
Ok the field decreses as ##\frac{1}{r^2}## and the spherical surface element centered at the point charge grows as ##r^2sin\theta d\theta d\phi##
And so the integral is not zero.
