Integral Equation (or I think so) Calculus I problem
The discussion revolves around finding a continuous function \( f \) that satisfies an integral equation involving \( f \) itself. The problem is situated within the context of calculus, specifically dealing with integral equations and differentiation.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to differentiate the integral equation to derive a differential equation. They explore the implications of their differentiation and the resulting expressions for \( f(x) \). Some participants question the correctness of the constant \( c \) in the solution, leading to discussions about the integration process and assumptions made during the derivation.
Participants are actively engaging with the problem, offering corrections and alternative approaches. There is a recognition of mistakes in the original reasoning, particularly regarding the integration of constants. Some participants suggest simpler methods to arrive at the solution, indicating a productive exchange of ideas without reaching a definitive consensus.
There are mentions of technical issues with LaTeX formatting, which some participants express frustration over. Additionally, there is a concern about the level of mathematical concepts introduced, as some participants aim to keep the discussion within the bounds of what has been formally studied in their course.
SqueeSpleen
Find a continuous funciton ##f## such that
f(x) = 1+ \dfrac{1}{x} \int_{1}^{x} f(t)dt
I think I solved it but I would like to see if it's right.
Well, first of all, by the fundamental theorem of calculus I know that
\left( \int_{1}^{x} f(t)dt \right) ' = f(x)
What I did was differentiate the original equation, to get a differential equation
f'(x) = \left( -\dfrac{1}{x^{2}} \right) \int_{1}^{x} f(t)dt + \dfrac{1}{x} \left( f(x) \right)
f'(x) = -\dfrac{1}{x} \left( \dfrac{1}{x} \int_{1}^{x} f(t)dt \right) + \dfrac{1}{x} \left( f(x) \right)
Well, by our first equation we have
\dfrac{1}{x} \int_{1}^{x} f(t)dt = f(x)-1
So using that we have
f'(x) = -\dfrac{1}{x} \left( f(x)-1 \right) + \dfrac{1}{x} \left( f(x) \right)
f'(x) = -\dfrac{1}{x} f(x)+\dfrac{1}{x} + \dfrac{1}{x} \left( f(x) \right) = \dfrac{1}{x}
So ##f'(x)=1/x##. Before I started this thread, I verified it a good amount of times and I always reached ##f'(x)=1##, so I guess I found at least one mistake in what I was doing. Wrote it to a forum really helps me to put my ideas together.
We integrate and we have
f(x) = ln(x)+c
Now when this is true.
= 1 + \dfrac{1}{x} \left (xln(x)-x+c \right)
= 1 + ln(x)-1+c
=1+ln(x)-1+\frac{c}{x}
So ##c=0##. Other way to check this is to notice that ##f(1)=1##, so ##c=0## because the integral is zero when ##x=1##.
Is this right? Another thing, I had problems with the TeX in the forum, half of it doesn't want to compile and I really don't know why. I don't know how to use the old [tex][\tex], only how to use double dollar symbol to make an entire row of latex.<br /> <br /> <Moderator's note: technical edit on LaTeX code. fresh_42. Please correct eventual mistakes.><b><br /> <br /> </b>[/tex]
One mistake I found is that for ## f(x)=ln(x)+c ## , ## c=1 ## (not zero). (Your Latex is hard to read. I think you missed a Latex parameter somewhere.) ## \\ ## (And I checked this solution by integrating the right side. It checked.)
Sorry, initially it didn't even compile and after trying for a while and being unable to find what was wrong I posted it anyway. Moderator corrected the mistakes but I still don't know which they were. Yes, it has a lot of sense because ##ln(1)=0##, so ##c## must be ##1##, but I don't know where I commited the mistake that made ##c=0##. I'll re-read this.
## f(1)=1 ## so that ## ln(1)+c=1 ##. But ## ln(1)=0 ## so that ## c=1 ##.
Yes but I'm having the following problem. I arrived to:
f(x) = ln(x)+\frac{c}{x}
Which implies that ##c=0##, which is not true (for the thingsd you're saying). But... I'm not really sure where did I make the mistake.
Edit: Found the mistake, I have to integrate c too, I put it outside the integral as it was the case of an indefinite integral.
That equation that you just edited needs a ## cx## instead of ## c ## which simply makes both sides equal.
= 1 + \dfrac{1}{x} \left (xln(x)-x+cx \right)
= 1 + ln(x)-1+c
=1+ln(x)-1+c
Well, this achieves nothing but verification, so this equation was redudant (but at least it's not contradictory as it was with the mistake).
Now, ##c=1## because the of what you said, that's caused because the integral nullifies when ##x=1## as it's an integarl over a point which is always zero (at least when it's a riemann integral as is the case and always is in Calculus I).
Edit: Thank you very much!
Multiply the initial equation through by [itex]x[/itex] to obtain
[tex]xf(x)=x+\int_{1}^{x}f(t)dt[/tex]
Then simply differentiate using the fundamental theorem of calculus and the product rule to obtain:
[tex]f'(x)=\frac{1}{x}[/tex]
= 1 + ln(x)-1+c
=1+ln(x)-1+c
It would have been much faster and much more straightforward to look at ##F(x) = \int_1^x f(t)\, dt##, and note that it satisfies the DE
$$\frac{dF(x)}{dx} = 1 + \frac{1}{x} F(x), \; \; F(1) = 0.$$
The solution is easily obtained as ##F(x) = x \ln x##, and from that you get ##f(x)## as ##f(x) = F^{\prime}(x)##.
Note: please do not write ##ln(x)## or ##ln x##; it looks ugly. The correct LaTeX form is ##\ln(x)## or ##\ln x##, which is obtained by writing "\ln" instead of "ln". The same applies to other familiar functions like log, sin, cos, tan arcsin, arccos, arctan, sinh, cosh, tanh, lim, sup, inf, max, min, exp, gcd, etc. TeX/LaTeX is designed to work properly when these are preceded by a "\".
Yeah, but I was trying to let this elementary. As they hadn't studied DE formally in this course, I didn't want to mention that's a DE.
But in the end what I'm doing is variation of parameters...
But yeah, your solution and huntman's one are way more straightforward, and even if I wanted to keep it elementary I could have done as you say without neccesarily introducting the concept of differential equation.
Thanks for the answers, if someone ask me again about those problems I will use your solutions as they're way easier to follow than my mess.
  • · Replies 34 ·
