Integral of 1/u^n knowing integral of 1/u
  • Thread starter Thread starter ezintegral
    Integral
The discussion focuses on finding the integral of the function 1/(x^4 + 1) and deducing the integral of 1/(x^4 + 1)^3 from it. The integral of 1/(x^4 + 1) is computed using partial fractions and results in a complex expression. It is established that there is no general method to compute ∫1/u^n knowing ∫1/u, as the two integrals are not directly related. The discussion concludes that integration by parts can be used to derive a recursive relationship for these integrals.
  • Understanding of integral calculus, specifically integration techniques.
  • Familiarity with partial fractions decomposition.
  • Knowledge of integration by parts.
  • Basic understanding of hypergeometric functions.
  • Study the method of partial fractions in detail.
  • Learn about integration by parts and its applications in recursive relationships.
  • Explore Gauss hypergeometric functions and their role in integrals.
  • Practice solving integrals involving higher powers of polynomials in the denominator.
Students and professionals in mathematics, particularly those studying calculus and integral equations, as well as educators looking for examples of complex integration techniques.
ezintegral
Hello,
This is the initial problem:
Find the primitive of 1/(x4+1)
i've done this, the value of the primitive is this ugly looking expression:
http://image.bayimg.com/d9ac5052a83d5808955a7a647c6cb7343f9ace1f.jpg
Now the question asked is to deduce the primitive value of 1/(x4+1)^3 from what I found.
This is why I'm asking if there is any general method to compute the value of ∫1/u^n knowing ∫1/u
Thank you
No, essentially there isn't. \int \frac{1}{(1+x^4)^3} is solved through partial fractions.
ezintegral said:
Hello,
Your image isn't showing.
Two comments here:
1. The two formulas are not related.
$$ \int \frac{du}{u^n} = \int u^{-n}du = \frac{u^{-n + 1}}{-n + 1} + C$$
$$\int \frac{du}{u} = ln|u| + C$$
The integrals you show don't fit either of these formulas, because if u = x4 + 1, then du = 4x3dx, which you don't have.
2. You have omitted the differential du from your integrals above. This isn't so crucial in the early stages of learning integration, but it is for more complicated methods such as integration by parts and trig substitution.
Thanks for the answers.
I'm going to try rewriting 1/(x4+1) in partial equations and see what I can get.
Presumably you mean 1/(x4 + 1). At the very least, use '^' to write this as 1/(x^4 + 1).
As for breaking up 1/(x4 + 1) using partial fractions, I don't see how this will do you any good. The denominator cannot be reduced to lower-degree factors with real coefficients.
It would help if you showed us the exact problem you're working on.
Mark44 said:
... The denominator cannot be reduced to lower-degree factors with real coefficients.
x4 + 1 can be reduced to lower-degree factors with real coefficients, but not to lower-degree factors with integer coefficients.
x^4+1=(x^2+(\sqrt{2})x+1)(x^2-(\sqrt{2})x+1)
This problem is presented in 2 questions.
1) Find the primitive of \frac{1}{x^4 + 1}
This is done, no particular problem. You get this:
2) Deduce the primitive of \frac{1}{(x^4 + 1)^3} from the primitive of \frac{1}{x^4 + 1}
Now the problem is with 2). I don't see how I can use the first result to find the second one.
Thank you for your time.
Thanks...
The image above is attached here.
dextercioby said:
I_{n} = \int\frac{dx}{\left(1+x^4\right)^n}, \\ ~, n\in \mathbb{N}
Point 1 asks you to compute I1. I3 follows from twice part integration.
Integration by parts once is enough to determine a recursive relationship of the form I_{n+1}(x)=f(x, n)I_n(x)+g(x, n). I_3 can then be expressed in terms of I_1(x) by using that relationship twice.
Thank you, this looks promising and within my reach.
  • · Replies 24 ·
