How Do You Simplify the Integral of a Rational Function?
  • Thread starter Thread starter Arman777
    Function Rational
The discussion centers on simplifying the integral of a rational function, specifically ∫dx/(x^2-1)^2. Participants suggest using partial fraction decomposition, with various approaches discussed, including representing the integrand as a sum of simpler fractions. There is a debate over the complexity of the method, with some expressing frustration at the length and difficulty of the problem. The integral can be solved, but it requires careful handling of coefficients and may involve multiple steps. Ultimately, the conversation highlights the challenges of integration and the necessity of persistence in finding solutions.
Arman777
Insights Author
##∫\frac {dx}{(x^2-1)^2}##
I tried to divide ##\frac {1} {(x^2-1)^2}## as ##\frac {Ax+B} {(x^2-1)} +\frac {Cx^3+Dx^2+Ex+F} {(x^2-1)^2}##
but this looks so complex..I don't know how to do ? Maybe I can just left at simpler terms.But how can I decide it ?
One trick is to just use a single label for a polynomial:
##\frac {1} {(x^2-1)^2} = \frac {A(x)} {(x^2-1)} +\frac {B(x)} {(x^2-1)^2}##
And see what that leads to.
Is this specifically meant to be done by partial fractions? I would try a trig substitution first. Didn't do it so I don't know what happens.
Doesn't it lead to ##A(x) =0## and ##B(x) =1?##
However, the OP could certainly get
$$\frac{1}{x^2-1} = \frac{A}{x-1} + \frac{B}{x+1},$$
and thus get
$$\frac{1}{(x^2-1)^2} = \frac{A^2}{(x-1)^2}+ \frac{2 A B}{(x-1)(x+1)} + \frac{B^2}{(x+1)^2}, $$
then do something with that.
If the integral is meant to be evaluated using partial fractions, I would decompose the integrand like this:
##\frac 1 {(x^2-1)^2} = \frac 1 {(x - 1)^2(x + 1)^2} = \frac A {x - 1} +\frac B {(x - 1)^2}+ \frac C {x + 1} + \frac D {(x + 1)^2} ##
Likes PeroK
There is another solution!
I get ##A(x)=0##
##B(x)-2A(x)=0##
##A(x)-B(x)=1##
whats the other solution ?
Is it make things easier ? (I am not sure..)
and thus get
can lead us yes but too long...
Arman777 said:
I get ##A(x)=0##
##B(x)-2A(x)=0##
##A(x)-B(x)=1##
The other solution is fairly obvious, but it doesn't lead to a great improvement. You shouldn't have been so hasty to dismiss @Mark44's suggestion. I think your definition of what is "too complicated" is no longer appropriate for the level of mathematics you are dealing with. You shouldn't be baulking at only four coefficients.
Its not too hard to find a b c d but after that.We will left another ##(x-1)^2## and ##(x+1)^2## so I have to do all stuff again..Fine I ll try
Arman777 said:
I get ##A(x)=0##
##B(x)-2A(x)=0##
##A(x)-B(x)=1##
whats the other solution ?Is it make things easier ? (I am not sure..)can lead us yes but too long...
Not too long at all. Sometimes things need considerable work, and there is no way to avoid doing it. Sometimes there are just no shortcuts.
The answer is ##\frac {1} {4} ln (\frac {x+1} {x-1}) - \frac{x} {2(x^2-1)}+C##
I ll find soon
yeah I know..But they shouldn't made such long questions
Real life isn't always about short questions.
You never told us whether you had to use a specific technique (such as by using partial fraction decomposition). Another approach that was already mentioned was trig substitution.
You are right.The question is in the partial fraction section
"Nature laughs at the difficulties of integration." - Laplace
Likes Arman777
I tried every method that we thought but nothing came up
What partial fraction representation are you trying to use? Which parts yield "nothing"?
Its too long to write down here :/.I can take photo maybe..Or I ll ask just my prof more simple
  • · Replies 105 ·
  • · Replies 18 ·
