Integrate (x^2)exp(-x^2)dx from - to + infinity
4 replies · 10K views · last reply
clope023
Hello, I'm doing a quantum mechanics problem from Griffiths chapter 1 where I'm trying to find the expectation value of x^2 given the function ρ(x) = Aexp[-λ(x-μ)^2].
The problem is in the title, but I'll rewrite it here simplified:
∫(x^2)exp(-x^2)dx
Subbing u = x^2 <=> x = sqrt(u) => dx = -0.5(u^(-1/2))du which becomes
-0.5∫(u/sqrt(u))exp(u)du = -0.5∫ sqrt(u)exp(u)du
So from here I tried integration by parts, u = sqrt(u), du = -0.5u^(-3/2)du,
dv = exp(u)du, v = exp(u)
uv - ∫vdu = sqrt(u)exp(u) + 0.5∫u^(-3/2)exp(u)du
From here I equatted this with -0.5∫sqrt(u)exp(u)du and noted
u^(-3/2) = (u^(-1/2))*(u^-1) = (u^(-1/2))/u
so then I did the algebra and got:
∫u^(-1/2)exp(u)du = u^(-1/2)(u/(u-1))exp(u) = sqrt(u)exp(u)/(u-1)
Am I on the right track? I am aware I can do this with the complementary error function or the gamma function but I'm trying to avoid using them. Any help is appreciated thank you.
∫(x^2)exp(-x^2)dx
You cannot avoid the error function, as it occurs in one term of the answer. Put it another way: if you could find a closed-form for the integral, involving only elementary functions, you could also find a closed, elementary form for the error function, and this is provably impossible.
RGV
Sure you can. The definite integral [itex]\int_{-\infty}^{\infty} x^2 e^{-x^2} dx[/itex] (which from the thread title is what is actually desired) can be computed by applying integration by parts once with [itex]u=x[/itex] and [itex]dv=x e^{-x^2} dx[/itex], and then computing [itex]\int_{-\infty}^{\infty} e^{-x^2} dx[/itex] in the usual way (multiplying by [itex]\int_{-\infty}^{\infty} e^{-y^2} dy[/itex] to give the square of the integral, converting this to a 2D integral in polar coordinates to easily compute it, and then taking the square root)
Of course the definite integral is doable---but not by the methods the OP posted. In the main body of the post the OP seemed to be wanting the indefinite integral, and I was responding to that.
RGV
Do you know the result
$$I(\alpha) = \int_{-\infty}^\infty dx~e^{-\alpha x^2} = \sqrt{\frac{\pi}{\alpha}}?$$
If you are allowed to use that result, you can find the values of the averages of ##x^{2n}## by supposing ##\alpha## is actually a variable parameter and taking derivatives with respect to it. e.g.,
$$I'(\alpha) = -\int_{-\infty}^\infty dx~x^2e^{-\alpha x^2} = -\langle x^2 \rangle_\alpha,$$
where I've used a subscript ##\alpha## to denote that it's still a variable, and you have to set ##\alpha## to be whatever it is supposed to be in your original integral.
This is by far the slickest way to get Gaussian averages, in my opinion.
