Integrating 1/(x^3-1) Using Partial Fractions - ∫1/(x^3-1)
  • Thread starter Thread starter arishorts
The discussion revolves around the integration of the function 1/(x^3-1) using partial fractions. Participants explore various methods and substitutions to tackle the integral, particularly focusing on the integration of the resulting fractions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of partial fractions and the values of constants A, B, and C. There are attempts to integrate the second part of the expression, with some questioning the choice of substitution. Others suggest using trigonometric substitution after completing the square.
The discussion is active, with participants offering various substitution methods and questioning the transitions between steps. Some guidance has been provided regarding the use of u-substitution and trigonometric substitution, but no consensus has been reached on the best approach.
Participants note the complexity of integrating the second half of the expression and the potential for simpler methods. There is an acknowledgment of differing algebraic manipulation skills among participants, which may influence their approaches.
arishorts
∫1/(x^3-1)
A/(x-1) + (Bx+C)/(x^2+x+1)
1=A(x^2+x+1) + (Bx+C)(x-1)
I've solved for all the variables in this...
A= 1/3
B= -1/3
C= -2/3
which gets me:
1/3*Ln|x-1| + ∫(-(x/3)-(2/3))/(x^2+x+1)
I can't figure out how to integrate the second half. Maybe I'm not using the right u (u-sub)? There's probably something really simple I'm not seeing.
What if you had 1/(ax^2+b)? Then you would use trig sub right? If you complete the square, then you'll be closer to this form.
Hi arishorts! Welcome to PF! :biggrin:
Try substituting [tex]u = x^2 + x + 1[/tex]
You already know this... but i get du=2x+1 dx, but the numerator is x+2. is there a transition I'm missing?
sorry, i didn't notice the x factor in the numerator, you should integrate that part spearately, you can use the easier u substitution.
I'm trying this right now, don't see why it shouldn't work. Is there not a simpler way?Edit:
This is what I'm doing right now:
-(1/3)∫ (x+2) / ((3/4)-(x+(1/2))^2)
Then i'd trig sub...
Write it as
[tex]\frac{1}{2} (\frac{2x+1}{x^2+x+1} + \frac{3}{x^2+x+1})[/tex]
And then complete the square.
du/2=(x+1/2)dx, then for the leftover (a constant in the numerator), complete the square then use trig sub.
no simpler way, that's why they teach trig sub
EDIT: Infinitum's last post looks good, use simpler u-sub on term on left, trig sub on right.
Infinitum said:
Write it as
how can you do that to the numerator, but not the denominator?
Is this correct?
[tex]\frac{a+b}{c+d} = \frac{a+b}{c} + \frac{a+b}{d}[/tex]
Put in some values to be sure :wink:
EDIT: it's up to you if you want to consider the x term in the numerator while doing trig sub, I was thinking a constant would be all you'd want to consider. the part with an x in the numerator, i usually go for the much "simpler" u-sub.
You seem to have a very strong algebraic manipulation background, where as i don't. Been trying to work on it lately. I'm trying all methods mentioned here (trying to make sense of it all).
Infinitum actually multiplied by 2(1/2), rather than (1/2)/(1/2). You see, they distributed the 2 to the numerator, and left the 1/2 out front.
do what to the numerator?
Infinitum said:
Is this correct?
not trying to be an ***...
a=1, b=2, c=3, d=4
3/7 ≠ 3/3 + 3/4
it was edited. the 1/2 wasn't there before or i didn't see it. i see it now. Let me try this.
Infinitum said:
Write it as
[itex]\displaystyle -\frac{1}{3}\frac{x+2}{x^2+x+1}=-\frac{1}{3}\frac{1}{2}\frac{2x+4}{x^2+x+1}[/itex]
[itex]\displaystyle =-\frac{1}{6}\frac{2x+1+3}{x^2+x+1}[/itex]
[itex]\displaystyle =-\frac{1}{6}\left(\frac{2x+1}{x^2+x+1}+\frac{3}{x^2+x+1}\right)[/itex]​
Got it! Thanks guys... Give you guys +rep if i could, but there doesn't seem to be that system here.
Just got it. Thanks.
