Integrating a trigonometric integral with multiple variables
  • Thread starter utkarshakash
    Integral
16 replies · 3K views · last reply
utkarshakash
[itex]\displaystyle \int^{\pi /2}_0 \dfrac{xcosxsinx}{(a^2 cos^2 x+b^2 sin^2 x)^2} dx[/itex]
2I = [itex]\displaystyle \int^{\pi /2}_0 \dfrac{xcosxsinx}{(a^2 cos^2 x+b^2 sin^2 x)^2} + \dfrac{(\pi /2 -x)cosxsinx}{(a^2 sin^2 x+b^2 cos^2 x)^2} dx[/itex]
How to simplify after this?
I couldn't think of a smarter way but the following should work.
You can write the given integral as
[tex]\int_0^{\pi/2} \frac{x\tan x \sec^2x}{(a^2+b^2\tan^2x)^2}dx[/tex]
Use the substitution ##\tan x=t## and then integrate by parts.
And what about your previous thread? Did you get the answer? :rolleyes:
^Are you trying to get the antiderivative? It is easy to get rid of the x in front by integrating by parts, but the new integral is hard. Perhaps the bounds can be used, but the a and b break the symmetry.
Yes, I am trying to find the antiderivative. The new integral isn't hard but only a bit lengthy (I think).
The new integral after substitution,
[tex]\int_0^{\infty} \frac{\arctan t\cdot t}{(a^2+b^2t^2)^2}dt[/tex]
This can be solved using integration by parts.
Yes I got the answer of previous question.
I found a shorter method.
Solve the given integral using integration by parts with ##u=x## and ##v## be the rest i.e
[tex]x\int \frac{\sin x \cos x}{(a^2\cos^2x+b^2\sin^2x)^2}dx-\int \left(\int \frac{\sin x \cos x}{(a^2\cos^2x+b^2\sin^2x)^2}dx\right)dx[/tex]
Use the substitution, ##(a^2\cos^2x+b^2\sin^2x)=t## that should give the answer.
This question is very easy by utkarshakash's method but he got afraid to see the big size of his integrand. :p
I too at first thought would use his method.
After simplifying you get,
2I=...This will eliminate x. No need to integrate by parts. :)
Hint: Then use the substitution as Pranav suggested. Take sqrt(denominator)=t...
No. How do you conclude that?
Isn't is obvious ?
Let
I=π/20∫{xcosxsinx}/{(a2 cos2 x+b2 sin2 x)2} dx
Then applying the property of definite integration,
I=π/20∫{(π/2-x)cosxsinx}/{(a2 cos2 x+b2 sin2 x)2} dx
On adding,
2I= I=π/20∫{π/2cosxsinx}/{(a2 cos2 x+b2 sin2 x)2} dx
Now take, a2 cos2 x+b2 sin2 x=t
[tex]\cos(\pi/2-x)=\sin x[/tex]
So what ?
cos x changes to sin x but sin x also changes to cos x. The net result remains, what I typed in my previous post. I have done such type of questions.
sankalpmittal said:
So what ?
You ignored the denominator when you applied the property.
sankalpmittal said:
So what ?
No. You are going the wrong way. Note that though cos x and sin x interchange, the coefficents are also reversed. [itex]a^2 cos^2 x + b^2 sin^2 x[/itex] changes to [itex]a^2 sin^2 x + b^2 cos^2 x[/itex]. Now you can't just add the numerator simply. You know what I mean.
Did you arrive at the answer? :smile:
I got the answer by your method. Thanks!
Glad to help!
Oh, I ignored the denominator when I applied the property ! :redface:
However, when you integrate by parts, you can also divide both sides by cos4x, and then take tan2(x) = t. This will simplify the integrand to a mere identity.
