Integrating by Partial Fractions
16 replies · 3K views
Electrowonder
None
I was doing this problem from Griffith's electrodynamics book and can't figure out how to do this integral. The author suggested partial fractions but the denominator has a fractional exponent which I have never seen for partial fractions, and so, I am unsure how to proceed. The integral I am working on is this:
$$\int \frac{Z-Ru}{(R^2-z^2-2RZu)^{3/2}}du$$
Where u is the variable of integration and all the other ones are constants.
No idea how to get started, please give a hint.
Electrowonder said:
Problem Statement: Integrating by Partial Fractions
Relevant Equations: None
For these sort of integrals, I prefer to use the substitution ##s^2 = R^2 + z^2 - 2Rzu##. I assume that should be a ##+z^2## in the denominator. Or, using the original variable:
##s^2 = R^2 + z^2 - 2Rz \cos \theta##
Sorry, that should be a +z^2 in the denominator.
PeroK
The original integral was
$$\int \frac{\sin (\theta) (Z-Rcos\theta)}{(R^2+z^2 -2RZcos\theta)^{3/2}} d\theta$$
If I use the substitution s^2, how do I do find ds?
PeroK
$$\int \frac{\sin (\theta) (Z-Rcos\theta)}{R^2+z^2 -2RZcos\theta} d\theta$$
The usual way:
##2s ds = \dots ##
Charles Link said:
I think you can split the numerator, with the first term being simple. For the second term, you integrate not by partial fractions, but rather integrate by parts.
$$\int \frac{z}{(R^2 + z^2 - 2Rzu)^{3/2}} du +\int \frac{-Ru}{(R^2 + z^2 - 2Rzu)^{3/2}} du$$
How would I integrate the second term? I have already done a U substitution, am I allowed to just do another substitution?
PeroK said:
The usual way:
##2s ds = \dots ##
Seems quite obvious but I have never done substitution with a quadratic before. Usually, you substitute with something like ##s = R^2 + z^2 -2Rzcos\theta## but I realized that won't go anywhere nice.
Using your way, I did
$$d(s^2) = 2sds = 2 \sqrt{R^2 + z^2 - 2RZcos\theta} d(\sqrt{R^2+z^2 -2RZcos\theta})$$
$$=2RZsin\theta d\theta$$
Plugging it in:
$$\int \frac{(sin\theta)(z-Rcos\theta)}{(s^2)^{3/2}} \frac{d(s^2)}{2Rzsin\theta}$$
$$\int \frac{z(sin\theta)-Rcos\theta sin\theta)}{(s^3} \frac{d(s^2)}{2Rzsin\theta}$$
$$= \frac{1}{2R} \int \frac{d(s^2)}{s^3} - \frac{1}{2z} \int \frac{cos\theta d(s^2)}{s^3} $$
Then I would solve ##cos\theta## from the original substitution to get
$$cos\theta = \frac{s^2 - R^2 - z^2}{2RZ}$$
Then substitute that into the last integral
Am I on the right track?
Plugging it in:
That looks too complicated to me. Instead, simply:
##2sds = 2Rz \sin \theta d\theta##
##\sin \theta d\theta = \frac{sds}{Rz}##
PS
## \Rightarrow \ \cos \theta = \frac{R^2 + z^2 - s^2}{2Rz}##
Thank you, I was able to fully solve it! That was a brilliant substitution, and now it seems almost obvious after the fact. But what thought process do I need to adopt to do smart substitutions like that in the future?
Can someone advise me how to also do it by partial fractions as the author suggested?
It's not hard to remember, because ##s## is the distance, which Griffiths denotes as the squiggly "r".
Oh that's right, got it, thank you. That should prove helpful for other problems.
The second term becomes ## \int -Ru \,(\frac{1}{RZ}) d(R^2+z^2-2RZu)^{-1/2} ##.## \\ ## You should be able to do this by parts routinely. Remember ## \int\limits_{a}^{b} u \, dv=uv|_a^b-\int\limits_{a}^{b} v \, du ##.
I'm not sure what to do with the ##\int v du## term, what is v going to be?
Charles Link said:
## v=(R^2+Z^2-2RZu)^{-1/2} ##.
The integral ## \int v \, du ## is straightforward.
Oh, I see you meant ##d[(R^2 +z^2 -2Rzu)^{-1/2}]##, I was a bit confused with the exponent outside as I haven't done this for 3 years.
