How do I rearrange and integrate dx/dt=k(a-x)(b-x) in order to graph x and t?
  • Thread starter Thread starter jhast1
    Integrating
The discussion revolves around the integration and rearrangement of the differential equation dx/dt = k(a-x)(b-x) in order to graph the relationship between x and t. Participants are exploring the implications of integrating this equation and the resulting expressions for x.
  • Participants discuss various integration techniques, including the use of partial fractions. There are attempts to derive expressions for x in terms of t, and some participants express uncertainty about the correctness of their results. Questions about the initial conditions and the values of parameters a, b, and k are raised.
The discussion is ongoing, with participants providing different interpretations of the integration process and questioning the assumptions made regarding the parameters involved. Some guidance has been offered regarding potential errors in integration and the implications of the initial conditions, but no consensus has been reached on the correct form of the solution.
There is a noted assumption that a and b are not equal, and initial conditions are specified in the context of the problem. Participants are also considering the implications of these conditions on the expected graphical output.
jhast1
I need to integrate dx/dt=k(a-x)(b-x) and then rearrange to find x
1/((a-x)(b-x))dx = k dt
Integrating dx using partial fractions:
1/(b-a)×(ln((a-x)/(b-x))=kt+c
when t=0 x=0
∴c=(ln(a/b))/(b-a)
then when I rearrange I get:
x=(e^((b-a)(kt+c))×(a-b))/((e^((b-a)(kt+c))-1)
Then I change the x to y and t to x so that I can graph it, but it doesn't give me the curve that I want, I have attached the graph. I am was assuming that it would give something like the black curve rather than the red one that it gave. Am I doing something wrong?
What are the values of a,b, and k?
positive integers
Hey jhast1,
I tried solving your equation, and when you say
"Integrating dx using partial fractions: 1/(b-a)×(ln((a-x)/(b-x))=kt+c"
I've got something which looks more like:
\frac{ln(x-a)-ln(x-b)}{(a-b)}=kt
But maybe I just made a mistake..
Here is my working.
This is nearly correct, but you have the argument of the log flipped. From looking at your attached work, it appears you integrated dx/(a-x) and dx/(b-x) incorrectly and this will be the source of your error.
Your work assumes a≠b and this is not stated, however, given the set up of the question (i.e it is not written as k(a-x)2) then I suppose you can assume this is not the case. Were there any conditions on a and b given after the question?
ok so I did that part again and i got:
ln((b-x)/(a-x))/(b-a)=kt+bThen I made x the subject and got this but I'm still not sure if it is right.
x=(e(b-a)(kt+c)-b)/(-e((b-a)(kt+c))-1)
where c=ln(a/b)/(b-a)
Edit: a and b are not equal
Looks like I get x=\frac { a{ e }^{ r }-b }{ { e }^{ r }-1 } \\ r=(b-a)(kt+c)
jhast1 said:
when t=0 x=0
∴c=(ln(a/b))/(b-a)
Where is this initial condition specified?
x=([]e(b-a)(kt+c)-b)/(-e((b-a)(kt+c))-1)
I think there are two small errors above - you missed a coefficient in front of the exp term and there is a stray minus.
In the original post. t=0 when x=0.
The conditions are given in the question I have:
a is the amount of substance A and b is the amount of substance B, at t=0. x is the amount of product that these substances have produced at time t.
I see where I missed those things, however this does still not give me the curve that I'm expecting. Unless it's supposed to give me this curve.
The statement 't=0 when x=0' appeared in the attempt at a solution section. Since it did not appear in the Problem statement section, I wondered where that initial condition came from.
I think you have a sign wrong.
Shouldn't that be c=ln(b/a)/(b-a)? Substituting that in the (corrected) previous equation allows a lot of simplification.
Btw, a check you can do on the answer is to let b tend to a and see if you get the right answer for the case b = a.
it should be 1/(a-b)×(ln((a-x)/(b-x))=kt+c
ehild
  • · Replies 54 ·
16K
  • · Replies 22 ·
